Is a Pilot Bearing and a Release bearing the same thing?
Old Jul 18, 2005 | 09:29 AM
litterbox's Avatar
I am a (Trial User) Army
Default Is a Pilot Bearing and a Release bearing the same thing?
The bearing that comes with aftermarket clutch kits, that's the pilot bearing right? Is that the same thing as the release bearing? Just two different words describing the same thing?
Old Jul 18, 2005 | 09:44 AM
Marauder's Avatar
Default Re: Is a Pilot Bearing and a Release bearing the same thing? (litterbox)
A pilot bearing is a regular style bearing that is installed in the flywheel to support the main shaft of the transmission.
The release bearing, or throw out bearing, is the one that gets installed between the transmission and the clutch, on the main shaft. This is what pushes on the pressure plate when you push the clutch in.
Old Jul 18, 2005 | 10:03 AM
litterbox's Avatar
Default Re: Is a Pilot Bearing and a Release bearing the same thing? (Marauder)
Ok, now the pilot bearing ususally comes with aftermarket clutch kits correct?
Does it look pretty similar to the release bearing?
Old Jul 18, 2005 | 10:44 AM
B96v6's Avatar
Most clutch kits will include both bearings. No, they don't look similar. The pilot bearing will be about 1.5 inches in diameter whereas the release bearing will be about 3 inches in diameter. The release bearing will fit on your slave cylinder inside the transmission. The pilot bearing, as mentioned before, will go on your flywheel.
B96v6
Marauder's Avatar
They are completely different.
Not all clutch kits some with a pilot bearing but most come with a release bearing.
Pilot Bearing
Throwout Bearing
Old Jul 18, 2005 | 10:53 AM
litterbox's Avatar
Ok, my kit came with the release "throwout" beaing.
I called inline pro and they told me the pilot bearing is actually a part of the flywheel that can be replaced if worn. I'll look and see if it's on the flywheel when i get home.
Old Jul 19, 2005 | 12:48 PM
B-twentyVTEC's Avatar
and knowing is half the battle.. G.I. JOE... hehehee.. sorry I just had to get that out...
Old Jul 19, 2005 | 01:04 PM
Luserkid's Avatar
Default Re: (Mr_WETTY)
Stop Post whoring.
Whenever i do a clutch i would always want to replace that bearing just because the tranny is off, and the flywheel is off. What better time.
Old Jul 19, 2005 | 01:27 PM
alleyezonme's Avatar
Default Re: (Luserkid)
^^ good idea
maybe even get the flywheel resurfaced
Old Jul 19, 2005 | 01:36 PM
litterbox's Avatar
Default Re: (alleyezonme)
FYI, k series flywheels do not need a pilot bearing.
Old Jul 19, 2005 | 02:19 PM
Toxidomask's Avatar
Default Re: (litterbox)
another thing, you have to remove the flywheel from the engine in order to remove the pilot bearing. FYI. you can tap it out from outside to inside. (when the flywheel is off ofcourse.
Old Jul 19, 2005 | 02:20 PM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">A pilot bearing is a regular style bearing that is installed in the flywheel to support the main shaft of the transmission.
The release bearing, or throw out bearing, is the one that gets installed between the transmission and the clutch, on the main shaft. This is what pushes on the pressure plate when you push the clutch in.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">They are completely different.
Pilot Bearing
Throwout Bearing
This guy is 100% correct.
Old Jul 19, 2005 | 02:22 PM
nub.96ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">FYI, k series flywheels do not need a pilot bearing.</TD></TR></TABLE>
Is it in the crank? Something has to support the input shaft... either a bearing or a bushing.
Old Jul 19, 2005 | 04:55 PM
litterbox's Avatar
Default Re: (nub.96ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub.96ek &raquo;</TD></TR><TR><TD CLASS="quote">
Is it in the crank? Something has to support the input shaft... either a bearing or a bushing.</TD></TR></TABLE>It's a bushing.
Old Jul 20, 2005 | 11:33 AM
Marauder's Avatar
Also, when you change a clutch, its also a good time to get a new rear mail oil seal. Especially if there is a lot of miles on it already, it only takes a few more minutes to change.
spens 91 Ef
29
Mar 8, 2009 08:15 AM
crxpwr1
11
Oct 2, 2006 03:45 AM
lsvtec101
Jun 8, 2004 08:08 AM
The Toecutter
Apr 24, 2002 07:24 PM
