Outer tie rod will it cause a clicking when braking?
Hey guys i think my outer tie rod is going bad when i brake i hear a clicking noise like my brake system is loose but i checked all of that. So when i brake it clicks is this a tie rod?
Possibly. You can jack the car up and try moving the wheel side to side to check for play, but imo you should take it apart and visually inspect it by hand. Another area you might want to check are your bushings in the lower control arm. Mine were so worn out the inner ring was hitting the outter ring when braking and making a clicking noise. Replaced the bushings and no more clicking
tealchief
May 24, 2010 03:10 PM
Spence
Jul 18, 2005 03:55 PM
