which distributor can i use?
Old Jul 18, 2005 | 08:20 AM
chickenandpickles's Avatar
Default which distributor can i use?
i have a 90 crx si with the original d16a. My distributor has gone bad and i need to replace it. What distributor can i replace it with? Or what internal can i use in it to see if it will fix it?
Old Jul 18, 2005 | 11:05 AM
EF_9's Avatar
crx hf /si
Old Jul 18, 2005 | 11:06 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">crx hf /si</TD></TR></TABLE>
Old Jul 18, 2005 | 11:20 AM
Bunger's Avatar
Default Re: (Ace$nyper)
crx hf / si
civic si / ex
Old Jul 18, 2005 | 01:48 PM
im in canada, we have no hf model. Can i use one from a 1.5 l civic? is there any integra ones that will work?
Old Jul 18, 2005 | 01:57 PM
EP3_05's Avatar
Default Re: (chickenandpickles)
The 1.5L will not work because it is dpfi and the integra will not bolt to the cylinder head. Just get one from an 88-91 civic/crx si.
Old Jul 19, 2005 | 08:44 AM
used si distributors are not found here and if one is its 200 bucks...lots of 1.5 ones though...can i turn a 1.5 liter one into an si one by putting the si coil and ignitor into it?
Old Jul 19, 2005 | 08:30 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chickenandpickles &raquo;</TD></TR><TR><TD CLASS="quote">can i turn a 1.5 liter one into an si one by putting the si coil and ignitor into it?</TD></TR></TABLE>
no - the 1.5 distributor doesn't have a cylinder position sensor in it (needed to run the MPFI) - coil and igniter are already the same
white90crxhf
Feb 16, 2010 11:13 PM
hmtcrxsir
Jan 4, 2007 11:17 PM
CivicK20
Dec 10, 2006 07:30 PM
DualCamDan
10
Oct 20, 2004 10:53 AM
ef civic
Apr 2, 2003 08:14 PM
