3mm headgasket too thick for b16block gsr head?
Old Jul 18, 2005 | 08:08 AM
T3T495GSR's Avatar
Default 3mm headgasket too thick for b16block gsr head?
im wondering if that setup is just too low of compression for a drag 3 kit
Old Jul 18, 2005 | 10:00 AM
tthame1's Avatar
Default Re: 3mm headgasket too thick for b16block gsr head? (T3T495GSR)
Well, that should put your compression @ 8.2:1 and yes, that is too low.
Old Jul 18, 2005 | 10:23 AM
Chip's Avatar
His compression will actually be 8.4:1. Sure, it's low, but it's not outrageous. A friend of mine ran 7.8:1 compression on his daily driven 81.5mm B16 with an SC61 and said it was fine. The compression has nothing to do with your lag. I went from 10.5:1 compression to 9.3:1 compression and spool up was unchanged.
Old Jul 18, 2005 | 11:04 AM
11psiTurboSI's Avatar
Default Re: 3mm headgasket too thick for b16block gsr head? (Chip)
I run 8.8:1cr on my 81mm B16a2 and have no complaints.
ef_si
Jul 25, 2013 02:09 PM
Propulsion
Nov 24, 2003 09:16 AM
K20 EG
Jun 17, 2003 11:26 AM
