Leaky fuel injectors
Old Jul 18, 2005 | 05:46 AM
Ronin150's Avatar
Default Leaky fuel injectors
Well I got my car almost running. So close but yet so far. But down to the questions. I took the two injectors off that were leaking and looked at the green o-rings. One basically fell off in my hand. I tried to replace it with an o-ring that fit, but I guess it didn't because when I went to start the car again. Gas was spraying out from the top of the injector.
My question is, is there a bottom o-ring that might need to be replaced, and also is there something that could not be working in the fuel rail.
TIA
Old Jul 18, 2005 | 01:34 PM
fracas's Avatar
mark sure ur o rings are all good. and you will have o rings that go into your manifold. Make sure all of them are seated right.
Old Jul 18, 2005 | 01:40 PM
Ronin150's Avatar
Default Re: (fracas)
I've checked the o-rings on the injectors, because that's where it is spraying from.
It's really odd.
Hanmin
Apr 16, 2009 09:42 PM
SiRay13
Oct 21, 2006 04:30 PM
EJ8VTEC
Sep 30, 2005 11:14 AM
allmotor.net
Sep 27, 2004 11:57 AM
EGHatchy
Jul 8, 2002 01:35 PM
