Greddy Turbo Timer on a 88 CRX?
I can't seem to get mine working nor can I even find any info on how to hook this TT on my 88 HF.
This is probably the closest thing that I have found to get my TT working. I've tried it and it still doesnt work. Can anybody clarify this? I have double checked on my wiring, but ill triple check if I have to. Just want your opinions.
From Greddy and Honda Service Manual but use a test light to be sure
Greddy - Function - Honda
Red - 12v - White/Black (Constant whether key is on or off)
Grn - ON - Blu/White (Hot when car is in Run Position)
Blu - ACC - Wht/Red(hot when key in 1st position)
BlK - GRD - Any Chassis Ground(should be able to get this one yourself)
Brn - PRK - Parking Brake or Ground(Same here)
Purple - SPD - Speed Sensor(ne too nessecary, but might need to gnd)
I can tell you this, I had a brand new greddy timer on my old 00' Civic, the bitch never worked right. It would work right for maybe a week then stop, then it would start interfeering with my alram, then it would let the car run and not shut off until I manually cut off the timer. When I boosted my 2nd car I used a little bltz tt, no probs at all. I just think with the Greddy units you have a 50/50 chance of getting crap.
-red on timer to solid white wire on ignition
-blue on timer to solid yellow wire on ignition
-green on timer to black/yellow wire on ignition
-black on timer to ground
~Purple - SPD - Speed Sensor ~ (i just left it un hooked, no problems)
i just hooked a Blitz one up in my 90 CRX
is it me? or am i going crazy? i've tried your combination all sorts of combinations...swiching wires around and still it aint working for ****! >:[
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 »</TD></TR><TR><TD CLASS="quote">is it me? or am i going crazy? i've tried your combination all sorts of combinations...swiching wires around and still it aint working for ****! >:[</TD></TR></TABLE>
its working, just that it wont stay on to shut off the car. It shuts off with the car.
you dont have ur red wire hooked up to the constant from the sounds of it. i did the same thing at first, did u wire up ur ebrake wire? u could always try grounding it and see if it makes any differance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by singlecamdan »</TD></TR><TR><TD CLASS="quote">you dont have ur red wire hooked up to the constant from the sounds of it. i did the same thing at first, did u wire up ur ebrake wire? u could always try grounding it and see if it makes any differance</TD></TR></TABLE>
I had my red hooked up to either white or white/black. Both are constant 12v. Yes I did hook up my ebrake wire.
I had my red hooked up to either white or white/black. Both are constant 12v. Yes I did hook up my ebrake wire.</TD></TR></TABLE>
i think theres some kinda differance. my only sujestion would be to wire it up the way i said before! i wired my blitz one up that way and it works great. if your not gonna try it good luck figuring it out otherwise...
i think theres some kinda differance. my only sujestion would be to wire it up the way i said before! i wired my blitz one up that way and it works great. if your not gonna try it good luck figuring it out otherwise...</TD></TR></TABLE>
ive tried it your way. your way is the standard way....red-white, blue-yellow, green- black/yellow. my **** is tricky.
