interesting theory on exhausts
Old Jul 17, 2005 | 09:12 PM
5w20's Avatar
Default interesting theory on exhausts
Hey guys I just got done reading a good article in the May 2005 issue of Popular Hot Rodding Magazine. The article was written by David Vizard who seems to be one of the most accredited and respected people in the automotive performance world. In the article he stated that CFM is a great way to help develop a zero loss exhaust system. For zero loss a exhaust must flow 2.2 CFM per horsepower(This means less than 1% of total power produced by the engine is lost due to back pressure.). From reading the article I think that a lot of people that see gains when going from a 2.5” exhaust system to a 3” dual system see them because the muffler on the 2.5” system didn’t flow enough for their application. David stated that per square inch of exhaust tubing there is 115 CFM of flow. So plugging some numbers into the good ole TI-89….. ((3.14 * radius^2)*115[*2 for a dual exhaust system])/2.2 = Max hp supported with zero loss
A 2.75” (stock) single system is good for a 310hp engine with zero loss…
A 3” Single system is good for a 370hp engine with zero loss…
A 3.5” Single system is good for a 503hp engine with zero loss…
A 4” Single system is good for a 657hp engine with zero loss…
A 2.25” dual system is good for a 457hp engine with zero loss…
A 2.5” dual system is good for a 513hp engine with zero loss…
A 3” dual system is good for a 812hp engine with zero loss…
Now these numbers are assuming that everything else is set up perfectly. The muffler must flow as much as the open pipe or more to get zero loss at the listed hp levels. He also states that using a muffler with a larger inlet/outlet diameter than your exhaust pipe is a great way to get more out of a smaller diameter system since the muffler flow will be able to match the straight pipe flow. Now there are many other things to consider when designing an exhaust system but I figured this would give a great foundation to build on.
Just a side note that he stated that I thought was neat... “Just as fish don’t feel the weight of water, we don’t readily appreciate the weight of air. Just to set the record straight, a cube of air 100 feet square will weigh 38 tons!”
Hopefully I’ll get some more understanding of flow in a closed space in my fluid dynamics class next semester.
This was quoted from another site.
Old Jul 17, 2005 | 10:07 PM
King-Kong's Avatar
Default Re: interesting theory on exhausts (5w20)
interesting, i miss my old ti-83
speedstar-racing
Performance
213
Nov 8, 2008 06:56 AM
WanderingSamurai830
40
Mar 13, 2007 12:26 PM
teggsr925
Feb 17, 2006 12:42 PM
Tigfab
Welding / Fabrication
Feb 15, 2006 08:01 PM
Totoro
Oct 11, 2003 10:14 AM
