h23/vtec wont start
Old Jul 17, 2005 | 04:46 PM
high_revs's Avatar
Default h23/vtec wont start
just finished it, has compression, has fuel pressure, has spark......timing is aligned correctly, but to double check can any1 give me the timing marks on their h23 vtec's please..this is drivng me crazy.
Old Jul 17, 2005 | 05:42 PM
high_revs's Avatar
any1???
Old Jul 17, 2005 | 07:39 PM
high_revs's Avatar
nobody? i need my car running!!!! please help
Old Jul 18, 2005 | 04:52 AM
PirateMcFred's Avatar
Default Re: h23/vtec wont start (all mOtor h23)
Any other details than that? ECU? Ignition? Are all your connectors plugged in? Pull a sparkplug and see if it smells like gas... Give more details or no one will bother to help you since their guess is as good as yours. You cheater. haha
Pirate
Old Jul 18, 2005 | 07:42 AM
high_revs's Avatar
umm...i have a stock fpr....its at about 38 i believe according to my gauge...i have my p28 plugged in at 1st, but thoguht that might have been an issue so i switched over to my old p14.....there is spark...and theres is a smell of gas, but spark plugs were dry when i pulled them...im thinking it might be a timing issue....also the injectors are firing as they have pulse....
i need to see timing alignment makrs for this setup....i put the bottom crank gear to the lil arrow to the dot on the gear and the two cam gears with the arrows directly facing each other...tell me if i fucked up on that part, cuz everything else seems to be fine...
Old Jul 18, 2005 | 08:14 AM
92LudeSR's Avatar
Default Re: (all mOtor h23)
Someone else can back this up but the arrows on the cam gears should both be facing straight up. At least that is how a stock H23 is set up.
Old Jul 18, 2005 | 08:17 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all mOtor h23 &raquo;</TD></TR><TR><TD CLASS="quote">
i need to see timing alignment makrs for this setup....i put the bottom crank gear to the lil arrow to the dot on the gear and the two cam gears with the arrows directly facing each other...tell me if i fucked up on that part, cuz everything else seems to be fine...</TD></TR></TABLE>
Use the timing marks on the flywheel. The white plus sign is what you want to line up with the notches on the cam gears.
The up arrows on the cam gears should be pointing up and the notches on the sides of the cam gears should be pointing at eachother while the flywheel is at TDC. It will probaby be harder to do with the H23 block and H22 head....
Old Jul 18, 2005 | 09:36 AM
high_revs's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">
The up arrows on the cam gears should be pointing up and the notches on the sides of the cam gears should be pointing at eachother while the flywheel is at TDC. It will probaby be harder to do with the H23 block and H22 head....</TD></TR></TABLE>
damn the ******* timing is off...i hope my valves are still good.....but anyways i got a fidanza flywheel and it got no marks...put i'll put a screwdriver in the #1 cylinder to see when its top the center and face the arrows up on the cam gears...thanx...
Old Jul 18, 2005 | 11:09 AM
Hawkze_2.3's Avatar
A Fidanza does have marks (mine does anyway), but they're just little notches on the engine side of the wheel. I put some colored paint on mine so I could actually see them.
Old Jul 18, 2005 | 01:44 PM
high_revs's Avatar
well i'll have to look for mine then...anyways...it started up... idles like a champ.....no coolant issues or anything yet....havent hooked up vtec yet, and i still gotta install my o2 sensor...any1 know where i can get an o2 bung..i dont wanna rip on it till everything is right.
Old Jul 18, 2005 | 01:48 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all mOtor h23 &raquo;</TD></TR><TR><TD CLASS="quote">still gotta install my o2 sensor...any1 know where i can get an o2 bung..i dont wanna rip on it till everything is right. </TD></TR></TABLE>
Local exhaust shop should have them.
camshafted
Jul 18, 2010 10:56 PM
cammilian
Jan 8, 2009 07:03 PM
vtechswaphonda
Aug 2, 2007 01:04 PM
hybridpatient95
Jul 18, 2005 01:12 PM
