Compression gurus check in(Turbo D-series)
Old Jul 17, 2005 | 03:58 PM
portenio78's Avatar
Default Compression gurus check in(Turbo D-series)
I have noticed my turboed Z6 (original 169,000 miles) has been having a little ruff idle lately and sloppy starting, so I did a compression test and am a little confused.
170, 140, 160, 180. So cylinder 3 is low...could it be a ruff exhaust lobe on my cam(hence the idle?) I put oil in that cylinder and compreesion rose up significanly. Car drives fine, does not burn oil and my over flow is always at the same level. Also why might my center cylinders be lower than the outwers?
Old Jul 17, 2005 | 04:48 PM
5.0 Killa's Avatar
Default Re: Compression gurus check in(Turbo D-series) (portenio78)
Sounds like rings to me homie.
Old Jul 17, 2005 | 08:13 PM
foot's Avatar
Default Re: Compression gurus check in(Turbo D-series) (5.0 Killa)
If your compression goes up after adding oil to the cylinder it usually means the rings are failing.
Old Jul 17, 2005 | 08:15 PM
FortunateFool.'s Avatar
I just did a comp. test on my DNinja and got # 1.190 #2.195 #3.210 #4.190. Sounds like something else man. Are you positive you had a good tester ?
Old Jul 18, 2005 | 05:40 AM
portenio78's Avatar
Default Re: Compression gurus check in(Turbo D-series) (FortunateFool.)
ya brand new tester. Manual says that normal is 184, with lowest being 156. I guess I should start saving to build up my spare block huh.
WestyNaut92
May 21, 2018 05:20 PM
vtechjunkie
Apr 20, 2010 05:52 AM
Droppedatbirth!
15
Feb 2, 2004 06:36 AM
greenli0n25
Jan 26, 2004 07:29 AM
BoM
Jan 3, 2002 01:52 PM
