Obd1 Conversion ...DO i need to cut distributor leg?
Old Jul 17, 2005 | 01:44 PM
hotimportcrx's Avatar
Default Obd1 Conversion ...DO i need to cut distributor leg?
i have a distributor from a single cam vtec obd1 and im trying to make it fit but it seems not to be fitting right on my b16....im wondering if i cut the other leg it looks like it will fit...anyone ever heard of this?
Old Jul 17, 2005 | 03:12 PM
Cory man's Avatar
Default Re: Obd1 Conversion ...DO i need to cut distributor leg? (hotimportcrx)
Why are you using a sohc dist for your B series??? Using that dist and "modifying" the mounting leg might end up throwing your timing so far out that its not adjustable to within specs.
Old Jul 17, 2005 | 04:06 PM
ICeDoUt's Avatar
Default Re: Obd1 Conversion ...DO i need to cut distributor leg? (Cory man)
I've done it before, i used my HF dizzy and chopped a leg off of it to fit my b16, so yea it'll work, and my timing was perfecto!
Old Jul 17, 2005 | 06:16 PM
Cory man's Avatar
Default Re: Obd1 Conversion ...DO i need to cut distributor leg? (ICeDoUt)
IMO its so much easier to buy the correct part and know that you arent gonna have any timing/mounting issues after things are installed. You may be able to use the sohc dist after you modify the leg and retime everything. But if you have a B series dist you bolt in on, time it and go. Just my .02.
Old Jul 17, 2005 | 06:55 PM
njn63's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cory man &raquo;</TD></TR><TR><TD CLASS="quote">IMO its so much easier to buy the correct part and know that you arent gonna have any timing/mounting issues after things are installed. You may be able to use the sohc dist after you modify the leg and retime everything. But if you have a B series dist you bolt in on, time it and go. Just my .02.</TD></TR></TABLE>
cutting a leg on a distributor vs. spending $200+ on a new one. Don't see why someone would consider putting it on
Look at it this way, what is he out if it works? He has a dizzy sitting there he isn't going to use. It's way easier to buy a b-series distributor but what is the fun in that?
Old Jul 17, 2005 | 07:36 PM
Default Re: Obd1 Conversion ...DO i need to cut distributor leg? (njn63)
bump for more info......i think it will work but if its mounted at an angle or whatever the timing can be corrected right??? because after my harness comes in im going for tuning...so can they correct the timing then...??
Old Jul 17, 2005 | 07:39 PM
Bunger's Avatar
Ya, just have the rotor pointing at the #1 spark plug wire on the cap when the engines at TDC, this will get you close enough to start the car and time it with a gun.
Old Jul 17, 2005 | 07:49 PM
NikoZai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote"> It's way easier to buy a b-series distributor but what is the fun in that?</TD></TR></TABLE>
AHHAHAAHA
Get the right distributor and sell that distributor on ebay for $100+
Old Jul 17, 2005 | 10:17 PM
EFRue57's Avatar
Default Re: Obd1 Conversion ...DO i need to cut distributor leg? (NikoZai)
Look at it this way, what is he out if it works? He has a dizzy sitting there he isn't going to use. It's way easier to buy a b-series distributor but what is the fun in that?</TD></TR></TABLE>
because there is a difference in making it work and making it right. if honda had meant for that distributor to be on that motor, they would have put it on there to begin with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai &raquo;</TD></TR><TR><TD CLASS="quote">
AHHAHAAHA
Old Jul 18, 2005 | 07:15 PM
njn63's Avatar
he obviously knows that it would be easier to sell it and buy a b-series one. That's not why he's here. He's asking how to make it work or if it won't work period.
bump for real info
Old Jul 18, 2005 | 07:46 PM
ICeDoUt's Avatar
Default Re: (njn63)
Did anyone read my post?????? Its been done folks.... by MEEE. and i beat the living **** outa it, and it ran great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">I've done it before, i used my HF dizzy and chopped a leg off of it to fit my b16, so yea it'll work, and my timing was perfecto!</TD></TR></TABLE>
Why spend the cash when this works, and u don't have to wait for shipping, if need be. Just use what u got.
Old Jul 18, 2005 | 09:40 PM
Default Re: (ICeDoUt)
thanks for the info
Old Jul 18, 2005 | 09:50 PM
EFRue57's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">Did anyone read my post?????? Its been done folks.... by MEEE. and i beat the living **** outa it, and it ran great.
Why spend the cash when this works, and u don't have to wait for shipping, if need be. Just use what u got.</TD></TR></TABLE>
why spend the cash??? so you don't have ghetto rigged **** on your car. i can run v-tec with speaker wire to a toggle switch all day long, but it doesn't mean it's right. same thing applies here. but if you wanna have ghetto work on your car that looks like ****.........well that's your business. to ghetto fabbing.
Old Jul 18, 2005 | 10:43 PM
Bunger's Avatar
Default Re: (EFRue57)
Its been my experience that when you don't use all 3 bolts (esp if you use only 1), that the distributor doesn't sit flush with the head and it wears the bearings in the housing out much faster and leak oil.
Old Jul 19, 2005 | 02:44 PM
ICeDoUt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFRue57 &raquo;</TD></TR><TR><TD CLASS="quote">why spend the cash??? so you don't have ghetto rigged **** on your car. i can run v-tec with speaker wire to a toggle switch all day long, but it doesn't mean it's right. same thing applies here. but if you wanna have ghetto work on your car that looks like ****.........well that's your business. to ghetto fabbing.</TD></TR></TABLE>
I am Ghetto Fabulous, i wish i could mold a block out of JB Weld!
nyckid
Apr 5, 2015 11:28 AM
dem0nk1d
Jul 22, 2007 02:59 PM
1FSTNDN
Nov 7, 2005 02:44 PM
project civic
Mar 13, 2005 03:52 PM
photec3
Oct 1, 2003 01:15 PM
