HI Im New - Buying a Teg Type R (need advice)
Old Jul 17, 2005 | 01:31 PM
k31th's Avatar
Default HI Im New - Buying a Teg Type R (need advice)
Hi!
Right im looking to buy a Integra type R iv sorted the insurance (about to turn 21 its a nightmare). I have sourced a ITR for 5k it has done 98k is miles an issue with vtecs? i heard there **** hot and honda have not had one back in ten years?? basically im after some buying advice ill do a HPI and check all the obvious stuff but iv never owned a Honda before and wondered wat to look for when buying?
The one im looking at at has had one owner from new on a 98 plate and tells me its motorway miles, the only thing wrong with the car is a stone chip and a worn drivers seat... The car is totally standard and he wont take no less than 5 for it...
Any way rant over !!
Any help / advice would be great
Thanks !!
Keith
Old Jul 17, 2005 | 01:51 PM
ZygSpeed's Avatar
Default Re: HI Im New - Buying a Teg Type R (k31th)
Doesn't sound like too bad a price, depending on the conversion rate between USD$ and what, Euros or Pounds.
Have you taken it for a test drive yet?
High miles aren't necessarily a bad thing, but might work in your favor if you were to try and get the price down a bit. Good luck with it.
Old Jul 17, 2005 | 01:57 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k31th &raquo;</TD></TR><TR><TD CLASS="quote">Hi!
Thanks !!
Keith </TD></TR></TABLE>
Ha, I have a friend that graduated from University of Bath. I was out there once for a week, almost 6 years ago
Look for maintenance records. As long as you change the oil periodically, Honda motors are generally good for many (200K) miles.
Check for burning oil in VTEC, in higher RPM's. Accelerate to redline in first, make sure there's no cloud of smoke behind you. Also, if you can drive with a tailwind or no wind, accelerate in first, stop, and smell for burning oil with the window down. Something like that. Some black smoke is normal, that's from running a bit rich at full throttle.
Old Jul 17, 2005 | 02:04 PM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
Default Re: HI Im New - Buying a Teg Type R (Chris F)
heres your advice, dont
Old Jul 17, 2005 | 03:33 PM
k31th's Avatar
Default Re: HI Im New - Buying a Teg Type R (v-attack)
Dont buy it??
Other advice is to run it thru vtec at standard operating temprature and see if it smokes ??
Old Jul 17, 2005 | 04:07 PM
Phelixthecat's Avatar
hondas rot easily. check the body very meticulously for rust, including the wheel wells
Old Jul 17, 2005 | 10:47 PM
ITR9's Avatar
5grand? you live in Malta?? you sure its a typer?
PS- take the car to Honda/Acura and spend the $100 bucks, or $5 in your currency and get it checked out.
Old Jul 17, 2005 | 11:00 PM
Circa's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">Check for burning oil in VTEC, in higher RPM's. Accelerate to redline in first, make sure there's no cloud of smoke behind you. Also, if you can drive with a tailwind or no wind, accelerate in first, stop, and smell for burning oil with the window down. Something like that. Some black smoke is normal, that's from running a bit rich at full throttle.</TD></TR></TABLE>
A mechanic I work with told me this is a problem with honda DOHC motors.. he told me the only way to fix it is through a block rebuild
ive noticed the problem after running mine hard for a couple of weeks.. it doesnt cook oil, but the oil does depreciate a bit
how widespread is it? (do all ITRs have this problem?)
Old Jul 18, 2005 | 03:28 AM
k31th's Avatar
Im in the UK !! yrah ill get it checked it has had a HPI check and whne i put it in for a quote on insurance using the reg plate came up as a type are, its selling for that price due to the 98,000 miles im guessing !
Old Jul 18, 2005 | 04:20 AM
Chris F's Avatar
Default Re: HI Im New - Buying a Teg Type R (Circa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Circa &raquo;</TD></TR><TR><TD CLASS="quote">A mechanic I work with told me this is a problem with honda DOHC motors.. he told me the only way to fix it is through a block rebuild
how widespread is it? (do all ITRs have this problem?)</TD></TR></TABLE>
Yeah, a lot of ITR's burn oil. Not a big deal until you get to higher consumption rates.
Old Jul 18, 2005 | 04:36 AM
k31th's Avatar
What causes them to burn oil ? rings??? or wat... Anouther thing i was thinking is how long do these engine last for in general as they are very short stroke ?
2ndgent3g
15
Mar 30, 2008 08:24 AM
Formula52
21
Dec 30, 2007 11:33 PM
pushinlsteg
13
Jul 22, 2005 10:46 AM
mkiv98
Mar 20, 2005 06:42 PM
Hairy Gorilla
Jan 14, 2003 08:04 PM
