oil pan gasket
Actually.. when I used my oil pan gasket on my 4g, I used HondaBond and it leaked... second time around I didn't use any except for the half circle part, no leaks this time....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GaRn »</TD></TR><TR><TD CLASS="quote">Actually.. when I used my oil pan gasket on my 4g, I used HondaBond and it leaked... second time around I didn't use any except for the half circle part, no leaks this time....</TD></TR></TABLE>
tahts because your not suppose to use hondabond on the rubber gasket except for the corners.
and on the 5g its all hondabond, no gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR »</TD></TR><TR><TD CLASS="quote">Make sure you cake the rtv thick too.
Put the sealant on the pan and let it sit for a few hours
and harden up before you reinstall the pan.</TD></TR></TABLE>
I disagree. First, if you put too much on, most of it will just squeeze out on both sides, and it can come off on the inside and plug up the oil pickup. You want just enough to squeeze out when you put it together. I've worked on a H22 where they went nutz with RTV and the pickup was crammed with ribbons of RTV. Also, I think it's better to clean both mating surfaces, apply the honda bond (permatex grey) to the pan, and assemble immediately. I think the instructions on the tube say as much. Good luck...
StreetRacinThug
Dec 21, 2006 08:44 AM
ringgold
18
Sep 20, 2004 04:28 AM
