EG suspension on a 00 si
Old Jul 17, 2005 | 11:35 AM
TheThiefTheKnife'NTheGun's Avatar
Default EG suspension on a 00 si
Ok.. I have searched and found a few things but not a straight forward answer.
I have a delsol and I have spent tons of loot upgrading the suspension. Is there anyway to use it on the SI...
Old Jul 17, 2005 | 12:38 PM
RotiEatter's Avatar
Ditto
Default Re: EG suspension on a 00 si (justinwipf)
What are you looking to swap over?
Old Jul 17, 2005 | 01:46 PM
Default Re: EG suspension on a 00 si (RotiEatter)
well my main concern is just the coilovers.. But I have upper and lower control arms front rear sus tech sways. I am pretty sure the contorol arms wont work but I think maybe the rear sway will work and the coilovers but not sure
Old Jul 18, 2005 | 10:16 AM
uncle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinwipf &raquo;</TD></TR><TR><TD CLASS="quote">well my main concern is just the coilovers.. But I have upper and lower control arms front rear sus tech sways. I am pretty sure the contorol arms wont work but I think maybe the rear sway will work and the coilovers but not sure</TD></TR></TABLE>
I thought the only real differences were the LCA's. The coilovers will work.
Old Jul 18, 2005 | 03:44 PM
I know I cant use the LCA's But the rear strut mounts I think are bigger on the eg
Old Jul 19, 2005 | 05:24 PM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by justinwipf &raquo;</TD></TR><TR><TD CLASS="quote">I know I cant use the LCA's But the rear strut mounts I think are bigger on the eg</TD></TR></TABLE>
They are, the bottoms of the strut forks are slightly wider in the rear on the EG as opposed to the EK's. You can fill the space with washers on either side of the control arms on the EK and use the EG suspension. The difference is very minimal, about 1/8" gap on each side of the arm when you put the EG struts/coilovers on.
gsxr-t-bag600
Suspension & Brakes
11
Aug 22, 2010 11:51 AM
BF52
Suspension & Brakes
Jan 23, 2009 08:15 PM
92civeg
Suspension & Brakes
Nov 3, 2007 03:43 PM
spoonsiz88
Suspension & Brakes
Jun 25, 2006 10:36 PM
KStuned
Sep 22, 2002 09:44 PM
