Shifter very looose
Old Jul 17, 2005 | 09:25 AM
ghost_ryder35's Avatar
Default Shifter very looose
WHen I put my car in first you can move the shifter like 5 inches either direction. I've been told this is because the bushings in the shift linkage are getting worn. Is this where the problem is? ANy input would be great. About to swap my transmission so if the problem is in the likage i will just get some new bushings and push them in. Thanks!
Old Jul 17, 2005 | 10:21 AM
Default Re: Shifter very looose (ghost_ryder35)
bumpidy bumb bumb
Old Jul 17, 2005 | 10:29 AM
kim_2_da_chee's Avatar
Buy a shift linkage bushing kit.
You probably only need the bushing under your shifter (looks like a long U shaped thingy)
It doesn't cost too much, and installation is about 30 mins depending if your midpipe is a stuggle to loosen.
Good luck
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
The easy way to diagnose this would be to
put it on jack-stands>safely and have a friend move
the shifter for you so you can see where the slop is...
Old Jul 17, 2005 | 10:54 AM
Default Re: Shifter very looose (kim_2_da_chee)
thanks!
Axle Raynes
Jul 15, 2009 06:54 AM
elmalouno
May 2, 2008 08:37 AM
dr_latino999
22
Jan 15, 2007 04:14 AM
civicsitech91
Oct 26, 2006 08:20 AM
