something bad?????? :( :( :(
Old Jul 17, 2005 | 01:22 AM
ceLtic*
Guest
Posts: n/a
Default something bad?????? :( :( :(
ohhh man. what a long night....so im driving along and all of a sudden i hear "POW" and my car shuts off....and it starts back up. oK. fine.....i get to the light and the car just dies on me and wont start. [ls/vtec ctr pistons bc3+ cams rc 310injectors] and so on. now....after about 20 or so tries....its start up like normal....runs/revs all fine. then just hesitates and dies with loud back firing. I THINK the backfiring is cause im running RC 310 injectors and its dumping fuel into a hot motor and just spits it out, and POW.
my question is what could this be? bad spark plugs? bad injectors? bad distributor? what is going on..im so mad and in such a daze right now.... the engine will not throw any CEL's for the 1-2 minutes its running fine. anyone think the motor is blown?
edit: new water pump / oil pump /radiator as well. the car was not over heatting?
Modified by ceLtic* at 5:37 AM 7/17/2005
Old Jul 17, 2005 | 01:37 AM
AGENT 99's Avatar
Default Re: something bad?????? :( :( :( (ceLtic*)
Hm, maybe first thing is to check to fuel filter for a major clog.
ceLtic*
Guest
Posts: n/a
Default Re: something bad?????? :( :( :( (.ELMO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ELMO &raquo;</TD></TR><TR><TD CLASS="quote">Hm, maybe first thing is to check to fuel filter for a major clog.</TD></TR></TABLE>
any other ideas?
Old Jul 17, 2005 | 01:44 AM
AGENT 99's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic* &raquo;</TD></TR><TR><TD CLASS="quote">any other ideas? </TD></TR></TABLE>
No, not really.
Thats a weird problem though. WIll ask some friends.
(bump)
Old Jul 17, 2005 | 01:47 AM
ceLtic*
Guest
Posts: n/a
No, not really.
(bump)</TD></TR></TABLE>
thanks....im starting to think its the distributor though.
Old Jul 17, 2005 | 02:03 AM
BlueShadow's Avatar
maybe you should check with the guys in the NA forum? they deal with similar setups all the time.
Old Jul 17, 2005 | 11:33 AM
AGENT 99's Avatar
Default Re: something bad?????? :( :( :( (BlueShadow)
bump for an answer??
Old Jul 17, 2005 | 12:43 PM
N_A_is_best's Avatar
try new cap and rotor?
Old Jul 17, 2005 | 02:31 PM
whiteef8's Avatar
Default Re: something bad?????? :( :( :( (N_A_is_best)
tune up....cap,rotor, plugs,wires, and check timing/examine plugs to see whats goin on in the motor. just a suggestion. ^^ dude is right go to the NA Forum, much better knowledge...good luck
Old Jul 17, 2005 | 02:34 PM
wtsexton's Avatar
I'd check the rotor.
Mine did that when it came loose.
Old Jul 19, 2005 | 05:05 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (wtsexton)
damn, i thought you sold it LIAR, i guess i'm not letting you ride my r6
Old Jul 19, 2005 | 07:26 PM
ceLtic*
Guest
Posts: n/a
Default Re: (MugenHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenHonda &raquo;</TD></TR><TR><TD CLASS="quote">damn, i thought you sold it LIAR, i guess i'm not letting you ride my r6
its getting picked up this week f0q3r ed.
Old Jul 19, 2005 | 08:11 PM
myJDM89EF's Avatar
had a friend who had a similar problem and he changed out the plugs...plug wires.....and then put on new cap and rotor and the car has ran great.
B16Civic93
Jan 20, 2014 04:30 PM
Davidls
Jun 18, 2010 01:23 PM
castle1313
May 21, 2009 08:43 AM
ceLtic*
Jul 18, 2005 07:25 PM
