Welding STAINLESS steel...
Old Jul 16, 2005 | 11:06 PM
jfboy's Avatar
Default Welding STAINLESS steel...
I have to do a lot of stainless steel fabrication and I was wondering if you guyz could give me some pointers on satiless steel. I have never welded anything stainless steel.
Old Jul 16, 2005 | 11:11 PM
RCautoworks's Avatar
Default Re: Welding STAINLESS steel... (jfboy)
Tig or mig ?
Old Jul 16, 2005 | 11:55 PM
jfboy's Avatar
Default Re: Welding STAINLESS steel... (90blackcrx)
I dont even know what TIG or MIG means.
I have a lincoln semi(you adjust the speed and power and when you hit the trigger the wire is fed)
I am building a custom turbo manifold(dont worry i'm not starting from scratch I am merging 2 manifolds together)
I just need to make spot welds so once I am done with spot welding I will bring it to a shop to get the thing welded.
Old Jul 17, 2005 | 12:57 AM
ExploitedRacing-HR's Avatar
Wire Feed = MIG (basically... lets not get technical guys)
Anywho, to weld stainless steel with Wire-Feed welding or MIG, You will first need Tri-mix gas... and you will also need stainless steel mig wire which can be found at your local praxair or welding supply store.
Old Jul 17, 2005 | 01:01 AM
jfboy's Avatar
Default Re: (ExploitedRacing)
Do I need the gas even for spot welds ??? I dont have that setup.. can I do without it even for spot welds ?
Old Jul 17, 2005 | 06:33 PM
beepy's Avatar
Default Re: (jfboy)
Yes, you need the gas, even for spot welds.
You don't nessessarily need tri-mix. I have welded stainless just as well with cheap 75Ar/25CO2 or 100Ar.
Old Jul 17, 2005 | 07:14 PM
jfboy's Avatar
Default Re: (beepy)
Crap ! looks like I'm gonna has to fork a few hundreds to add the gas kit.
Old Jul 18, 2005 | 07:26 AM
beepy's Avatar
Default Re: (jfboy)
Honestly, I have welded stainless with flux-core wire before. I only did that because I ran out of gas and needed to make a quick repair.
But the weld will rust, and you will never be able to polish it up like the stainless.
Old Jul 18, 2005 | 04:35 PM
adeihl's Avatar
yup 75/25 works fine for SS
you can use flux core.. just wire wheel the spatter off... when the welder TIG's over it.. you wont even know your spot weld was there.
Old Jul 18, 2005 | 05:36 PM
Bailhatch's Avatar
Default Re: (adeihl)
I just tried 97argon/ 3co2 for stainless MIG. It worked really well, supposed to be a little better then trimix for material under 1/4".
Old Jul 18, 2005 | 06:17 PM
Engloid's Avatar
OG Fabricator
Default Re: (Bailhatch)
Pure argon works pretty well also.
Old Jul 18, 2005 | 07:24 PM
jfboy's Avatar
Default Re: (Engloid)
Can you guyz give me pointers on what the gas kit looks like. I think I know what it is but a picture would be nice to let me know I got teh right thing.
Old Jul 20, 2005 | 12:54 AM
ChainbreakR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Engloid &raquo;</TD></TR><TR><TD CLASS="quote">Pure argon works pretty well also.</TD></TR></TABLE> Have you had good luck with it? I have a hard time avoiding a high crown with it....
Old Jul 20, 2005 | 02:48 AM
adeihl's Avatar
ditto^^^^^^^^^^^ but that is usually more of a penitration issue.
Old Jul 20, 2005 | 03:59 AM
2point2's Avatar
do what i did! tack weld everything together with the MIG and have a pro TIG weld it.
Old Jul 20, 2005 | 07:49 AM
AccidentproWn's Avatar
Default Re: (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">do what i did! tack weld everything together with the MIG and have a pro TIG weld it.
isn't that what he said he was doing?
Old Jul 20, 2005 | 02:34 PM
ManBearPig4silly's Avatar
Default Re: (AccidentproWn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccidentproWn &raquo;</TD></TR><TR><TD CLASS="quote">
isn't that what he said he was doing?</TD></TR></TABLE>
yes.
Old Jul 20, 2005 | 05:43 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccidentproWn &raquo;</TD></TR><TR><TD CLASS="quote">isn't that what he said he was doing?</TD></TR></TABLE>
95ejjj
Welding / Fabrication
Apr 22, 2011 10:13 AM
Bjorn
Apr 14, 2009 08:26 AM
Rodney
20
Dec 9, 2008 04:08 PM
turbotime
Apr 15, 2006 11:43 AM
fandango
Mar 23, 2005 02:05 PM
