d series injectors on b16 swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 »</TD></TR><TR><TD CLASS="quote">It will work, same flow rate.</TD></TR></TABLE>
i had a chipped mugen p28 in my car and it wouldn't start and then my boy came by and let me put this gsr ecu in my car and the car started but it idle rough and the shop i got the ecu chipped at also told me that i have to use obd1 injector because i cinverted my car to obd1 so i did that but i'm use d series injector and it idles rough i was think that i have to get b series injector to put on my b series b16 what do u think and it the d series injector will work what do u think is wrong with the car and one other thing is that if i give it gas it will shut off that is y i think i need the b series injector i was told it lets more gas in the motor what u think
Didnt they just answer your question twice? The D series injectors will work fine. If you converted to obd1 and are using obd1 D or B series injectors did you cut the resistor box out and wire everything back up minus the resistor box?
