compression ratio question...
Old Jul 16, 2005 | 09:15 PM
d.n.d.'s Avatar
Default compression ratio question...
searched and didnt found what i was looking for so...
i have found that the compression ratio between the K20A2 and K20A3 (i think) cause the differences in hp #'s...so in theory (correct me if im wrong) could someone just raise the compression ratio of their A3 engine by putting something like a thinner headgasket....and achieve the same hp #'s as the A2??? or is there more to it???
Old Jul 16, 2005 | 09:35 PM
Tom5's Avatar
Default Re: compression ratio question... (drifter_X)
K20A3 = 9.8:1
K20A2 = 11:1
K20A = 11.5:1
A head gasket will only bump you up .4 -> from a 9.8:1 to a 10.2:1
There are numerous ways to bump the compression but the two easiest ways are pistons or a head gasket.
Old Jul 17, 2005 | 07:22 AM
Lucid Moments's Avatar
The compression ratio is part of the difference, but not all of it. As said in the previous post you can raise the compression ratio with a new head gasket, or pistons and that will increase the HP, but I don't think it will make all of the difference. The A2 has a much better flowing head and that makes some of the difference too. Now if you did a head swap, and increased the compression you would be pretty close to making up the difference.
Old Jul 17, 2005 | 08:39 AM
d.n.d.'s Avatar
Default Re: compression ratio question... (LucidMoments)
ohh ok then...makes sense
Acura-Power
Acura TL, RL & ZDX
May 23, 2024 05:10 PM
High Reved Racing
Jul 14, 2008 04:37 PM
spaceman
Mar 30, 2004 09:36 PM
aut0tek
Mar 18, 2003 11:00 AM
