will 92+ flywheel and clutch be a straight drop-in on a 91 crx si
Old Jul 16, 2005 | 08:48 PM
darrinbrewer's Avatar
Default will 92+ flywheel and clutch be a straight drop-in on a 91 crx si
i'm a integra guy, my ef and eg knowledge isn't the greatest, can my freind take a 92 SI fidanza flywheel and act clutch and go right into his 91 si Rex? or will just 1 of the 2 work? thanks! darrin
Old Jul 16, 2005 | 08:59 PM
d16vtecx's Avatar
Default Re: will 92+ flywheel and clutch be a straight drop-in on a 91 crx si (darrinbrewer)
yes but the clutch and flywheel must match and it will work
Old Jul 16, 2005 | 09:00 PM
seems the flywheel fits from what part#s i've checked, but clutch kits are differnet, anyone know what i need to make it work?
Mach69's Avatar
Im going to say yes. But the throw-out bearing is completely different (hydraulic vs. cable transmissions)
The flywheel will definately work, I know that 100%. Its the same dimensions and size as the '91 flywheel. And I know all D-series clutches had the same contact space sizes from 90-00 (8 3/8'', 212mm or 220mm, i forget which). I am pretty sure it will fit.
I'd get a second opinion, just in case.
Old Jul 16, 2005 | 10:38 PM
mcleod's Avatar
Default Re: will 92+ flywheel and clutch be a straight drop-in on a 91 crx si (Mach69)
90-91 flywheel are same as 92-00
90-91 clutch are same as 92-00
part number are different for the throw out bearing only!!
but 88 and 89 are not same as 90+
Old Jul 17, 2005 | 08:05 AM
myJDM89EF's Avatar
i have a friend who put a centerforce clutch and flywheel on a y7....thats almost the same
Old Jul 17, 2005 | 08:47 AM
zulued's Avatar
Default Re: will 92+ flywheel and clutch be a straight drop-in on a 91 crx si (myJDM89EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mcleod &raquo;</TD></TR><TR><TD CLASS="quote">90-91 flywheel are same as 92-00
but 88 and 89 are not same as 90+</TD></TR></TABLE>
this guy is right on the money...
90-2000 flywheel pressure plate and disk are the same.
the throw out bearings are different from cable to hydrolic trannys. thats what makes the part number different on the clutch kit
scarponze
Old Jul 17, 2005 | 09:30 AM
91civicDXdude's Avatar
i'll third this.
i've used many 92+ clutch kits on EF cars, and the only difference is the throwout bearing.
rex89sir2
Aug 28, 2009 02:36 PM
therealzk
17
Jan 12, 2008 03:06 PM
EFstyle
Jul 21, 2007 04:22 PM
5thGenKing
Oct 28, 2004 06:57 AM
the DR.
Feb 10, 2002 08:13 PM
