ECU QUESTION
Old Jul 16, 2005 | 08:34 PM
blackPiE's Avatar
Default ECU QUESTION
DOES AN ECU HAVE GOVERNOR. IF SO WILL IT PREVENT YOU TO GO A CERTAIN SPEED? CAUSE MY PRESSURE SWITCH GOES OFF ONLY IN 5TH GEAR ONCE AT 100MPH.
Old Jul 16, 2005 | 09:39 PM
mtber's Avatar
Default Re: ECU QUESTION (blackPiE)
Some ecus do have speed govs, but it would not cause you to throw a check engine light if you hit the gov.
Old Jul 16, 2005 | 10:57 PM
blackPiE's Avatar
Default Re: ECU QUESTION (mtber)
I checked my wires and sensor for loose connection. But everything seems ok.So what could it be?
BongoBennie
Engine Management and Tuning
Mar 15, 2018 11:42 PM
Low 4 Door
Jul 16, 2009 03:29 PM
Gsr Racer1
Mar 23, 2006 08:50 PM
ITACivic
Nov 19, 2002 04:37 PM
