Bogging with motor swap
Old Jul 16, 2005 | 06:47 PM
UNKNOWN_MEMBER's Avatar
Default Bogging with motor swap
Motor bogs as if timing is retarded. Tried advancing it more and still bogs. I rev it up, it revs up fine but real slow. Car is obd0 motor is obd1.
Cliffs notes:
-Modifed injectors for clips to fit (dremeled the tabs inside)
-Using obd0 distributor
-Old obo1 motor was working fine but with MSD digital 6 ignition external coil
-New motor was working fine in another car
Old Jul 16, 2005 | 07:13 PM
Vp Special K's Avatar
Default Re: Bogging with motor swap (UNKNOWN_MEMBER)
what ecu are you running?
Old Jul 17, 2005 | 12:57 AM
Default Re: Bogging with motor swap (Vp Special K)
p72 and tried a chipped p28. Both ecus ran fine before motor swap. Thinking it's misfiring, probably got firing order reveresed, will check out tomarrow.
Old Jul 17, 2005 | 09:34 AM
Suck my DX's Avatar
what is ur timing set at now?
Old Jul 17, 2005 | 12:24 PM
jdmcoop's Avatar
Default Re: Bogging with motor swap (Suck my DX)
is the timing belt teeth in right?
Old Jul 17, 2005 | 07:24 PM
ahh i got it. the firing order was wrong.
kasperxtcy
14
Jan 24, 2008 03:46 PM
sublimenerd
Sep 8, 2006 09:54 AM
jBj
Feb 19, 2006 07:09 PM
SKDRCR
Oct 1, 2004 07:42 PM
GhettoR
Jan 16, 2004 05:33 PM
