change tranny fluid.......
i have an h22 in my ek. i was reading some posts and they said that the 17mm nut was the filler hole, and the 3/8 was the drain. does this apply for all engines? i unscrewed the 17mm to check how much fluid i had left and all the damn oil came spilling out!! for the h22 are the bolts reversed? is the 17mm the drain and the 3/8 is the filler?
far as i know all honda manual trannies have the 3/8 hole as the drain and 17mm bolt as the filler... im not sure if this applies to the ep3 civics or rsx's though... never worked on one of those
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoGators »</TD></TR><TR><TD CLASS="quote">Rather than go by what size bolt is in the hole, wouldn't it make more sense to you that the filler hole would be above the drain hole?</TD></TR></TABLE>
this is true also... it should be above the passenger side axle
Thank you. It's common sense. Fill hole should be the one higher up. Drain, down below.
i-VTEC_DOHC
Honda Civic (2001 - 2005)
May 31, 2012 03:48 PM
Damon Reeves
Apr 15, 2007 09:11 AM
2lobes1engine
26
Jun 29, 2004 08:27 PM
Slammd Sol
Mar 28, 2004 10:21 AM
