Quik H22 in EK Questions...
Old Jul 16, 2005 | 04:43 PM
Sille98's Avatar
Default Quik H22 in EK Questions...
I did search...
I am trying to find out What alternator belt I need to use in my EK with my F20B (H22a).
I also need to know what Upper radiator hose to use. Thanks
Old Jul 16, 2005 | 07:21 PM
SixguN's Avatar
Default Re: Quik H22 in EK Questions... (Sille98)
For my alternator belt, I took a string and measured it around the pulley's, then counted the ribs in the pulley's, then I took it to a auto store and they sized one up for me. And for the radiator hose, I used one from a integra.
Old Jul 16, 2005 | 07:26 PM
Sille98's Avatar
Default Re: Quik H22 in EK Questions... (Sixgundone)
So one from a GSR would probably work since it is DOHC. Well so is the LS. I will try the GSR Radiator pipe I suppose...
Thanks for the reply...
Any other opinions are welcomed as I will be ordering these Monday morning...
Old Jul 17, 2005 | 05:45 PM
Sille98's Avatar
Old Jul 18, 2005 | 01:01 AM
SixguN's Avatar
I think they are the same. Also, just go to your local auto store and buy a teg upper radiator hose. If it doesn't fit, then eye it up and measure the outlets on the radiator, and the block.
That should do you just fine
You don't really need to go and order the hoses unless you want a specific color or something.
BOOSTonHAnD
Aug 9, 2006 12:52 PM
tr0n9h
Sep 30, 2005 11:06 PM
hybridevul
Jun 16, 2005 07:03 AM
hondastreet
Mar 17, 2004 09:32 AM
jeremy.
Mar 1, 2004 12:47 PM
