b20 vtec..oil pump problems
Old Jul 16, 2005 | 04:10 PM
MI4$DC5's Avatar
Default b20 vtec..oil pump problems
is there any modifications used to put a B16 oil pump onto a b20 block? im trying to put it on and it wont slide all the way on like my stock b20 oil punp does. Another question is can i run b20b oil pump and a gsr water pump?
Old Jul 17, 2005 | 12:00 PM
Slow ass EF's Avatar
Default Re: b20 vtec..oil pump problems (MI4EH2)
use GSR/ Type R/ B16 for ur oil pump, otherwise you mite not get adequate oil pressure during VTEC
Old Jul 17, 2005 | 07:31 PM
MI4$DC5's Avatar
Default Re: b20 vtec..oil pump problems (LSVTECJay)
I have a gsr one and it wont slide all the way on, but my b20 one slides on perfect..should i force the gsr one on? i dont know.
Old Jul 17, 2005 | 09:27 PM
snowseeker's Avatar
Yah, force it on with a hammer for 2 hours.
Did you check what is not meshing? Is the oil pump gear lined up right with the crank?
Old Jul 17, 2005 | 10:03 PM
MI4$DC5's Avatar
Default Re: b20 vtec..oil pump problems (snowseeker)
hell yeah i did, but ill go and try it again tomorrow and look real good...dam i hope this crap goes on.
Old Jul 18, 2008 | 10:33 PM
NAcoupeNA's Avatar
Default Re: b20 vtec..oil pump problems (MI4$DC5)
b20 oil pump share the same part number as vtec oil pumps, therefore its a vtec oil pump. no need to replace it for the same pump
Old Jul 18, 2008 | 11:40 PM
Tetanus's Avatar
Default Re: b20 vtec..oil pump problems (NAcoupeNA)
I'm sorry but I do not believe B20 engines share the same oil pump as VTEC motors. Someone correct me if I'm wrong but I think that guy above me is full of ****.
Old Jul 19, 2008 | 12:16 PM
Redline130's Avatar
Default Re: b20 vtec..oil pump problems (Tetanus)
OBD2 B20 oil pumps share the same part number as the VTEC oil pumps. They tend to be a bit cheaper too.
jdm-ek-si
Feb 10, 2009 02:51 PM
fkncivic
May 9, 2005 11:44 AM
infamousALLMTR
Nov 15, 2002 02:55 PM
another_import
Oct 21, 2002 06:30 PM
