Troubleshooting: Car idles low and dies
I have a 1990 CRX DX (B17 Turbo) and I was driving the other day and the car started to idle very low and when I come to a dead stop, sometimes it just shuts off. I parked it at home and the next day it was running fine...then later on in the day I was driving and the car died. I started the car up and revved it up to 6K to keep it from dying but it still dies out.
So I bought some engine starting fluid and had a friend start it up while i sprayed in the stuff into the throttle body. The engine stayed on as long as I sprayed. When I stopped spraying, the engine dies out.
I have a vacuum gauge and the vacuum is lower than normal so I checked around for vacuum leaks but can't find any leaks.
I have 450 DSM Injectors, V-AFC, Walbro 255 fuel pump. Car was dyno tuned too...
What could the problem be? A sensor? Or a fuel problem? (Locked/bad injectors?)
Any codes ?
Almost sounds like the iacv located on the back of the mani. If you ever leave it unplugged, the same thing you describe will happen
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpringPCS »</TD></TR><TR><TD CLASS="quote">Ok, noticed the plug for the IACV was unplugged. Plugged it back in but the same problem...it won't start up. </TD></TR></TABLE>
Well if it was unplugged then the car was throwing a code, did you reset the ecu ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpn211 »</TD></TR><TR><TD CLASS="quote">there might be a hole in your vacuum hose </TD></TR></TABLE>
Look for this or hooked up incorrect. Check valves or missing link?
DelsolioGSR1996
15
Sep 27, 2006 05:36 PM
FourthGenHatch
Apr 22, 2004 06:13 AM
