Omni Power Clutch Master Cylinder
The Omni-Power Quicklutch Master Cylinder has been designed to enable much faster shift times, with greatly improved clutch accuracy & feel. This is accomplished by utilizing a larger diameter piston, which moves the equivalent volume of fluid, with considerably less travel.
Benefits:
50% Reduction in Clutch Pedal Travel
User Adjustable Clutch Release Point
Improved Clutch Accuracy & Pedal Feel
Longer Transmission Synchro Life
Faster Recovery From Missed Gears
Restores Timing and Synchronization Between Short Shifter and Clutch Pedal.
5 year warranty from Omni Power
After you install a short throw shifter, your timing will be off from your hands to your feet. This in turn causes mis-shifts and accelerated wear on the transmission synchronizers. With the Omni-Power Quicklutch unit you will restore your shifting synchronization and it will enable you to make more consistent and faster shifts.
Used by many top winning racing teams across the world, they all agree this clutch master cylinder greatly improves shift times, some have stated that it’s the closest thing you can get to a sequential transmission.
$189
Order here: Omni Power Clutch Master Cylinder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Considering the problems with OEM Clutch Master Cylinders, im suprised no one made this part sooner.
I'll be picking one up along with a new clutch soon.
bambbrose
Jul 6, 2005 12:46 PM
mdixonjam
Jun 14, 2005 07:56 AM
