Clutch gone (again) wtf??
Old Jul 16, 2005 | 10:42 AM
RedKroovy's Avatar
Default Clutch gone (again) wtf??
Hey guys. I got a beater about a month ago and the R has mostly been sitting in the garage. I take it down the road here and there. Well last night My buddy who was down from college, asked for a ride. Long story short we get back to my driveway and the clutch petal goes to the floor and doesn't comeback up. It goes into any gear still. I can pull it back up but when I depress it again its mushy as ****. The shitty part is that I just got a new clutch and my fly wheel resurfaced in mid march.
Before I burned it up last night, I waited for it to come to temperature and everything was normal till I came back.
Thanks
p.s. Guys the car won't move. Its not like I can drive it we had to push it in the garage.
It goes in the gears but no movement. forward or reverse
I thought i explained that.
Modified by RedKroovy at 4:17 PM 7/16/2005
Old Jul 16, 2005 | 10:57 AM
Mythias's Avatar
Default Re: Clutch gone (again) wtf?? (RedKroovy)
Have you checked your clutch fluid?
Old Jul 16, 2005 | 11:00 AM
jar's Avatar
jar
Sounds like it needs to be bled.
Old Jul 16, 2005 | 11:18 AM
RedKroovy's Avatar
Default Re: Clutch gone (jar)
Would I bleed both cyclinders or just the master??
thanks guys. keep'um coming
Old Jul 16, 2005 | 08:32 PM
Arsenal's Avatar
Default Re: Clutch gone (Tweakmeister)
When you bleed you are trying to get the air out of the line, so in affect you are bleeding both but not really, just bleeding the system not the cylinders.
Simple task to do. 8mm wrench losen the nut a little, then down and up, with opening and closing the nut. repeat and rinse.
Old Jul 17, 2005 | 08:29 PM
ACTman's Avatar
At first I was thinking hydraulics, but that only affects disengagment. If the car won't move when it is in gear, you have something else wrong. broken diaphragm maybe? Expoded disc (linings blown off)? Anyone else have ideas? What else will cause the pedal to drop to the floor and prevent the clutch from transferring the power?
Old Jul 17, 2005 | 10:30 PM
MOVE OVER's Avatar
Default Re: Clutch gone (ACTman)
will it let u shift gears without the clutch pedal being down? (car on)
sounds very odd.
Old Jul 18, 2005 | 12:38 PM
Tweakmeister's Avatar
Default Re: Clutch gone (ITR 1102)
Okay, didn't see that in my original posts (car doesn't move).
As long as you're absolutely sure it won't move when engaged, you're going to have to pull the tranny off again and inspect the clutch.
mr abstract
Nov 27, 2006 10:56 AM
slowdaintegra
Dec 21, 2005 01:31 PM
96_GSR
Jul 31, 2002 06:32 PM
Powered by Honda
Apr 11, 2002 07:50 PM
