Fidanza Racing CV Axles any good? Other performance axles to go for?
hey kids,
Well I've just swapped in a JDM ZC tranny in my 90 Civic DX HB with the ole A6. I broke a CV Joint at the track tonight and need at least one new axle. I had an OEM 88-91 Civic Passenger side axle with ZC inner CV joint that I swapped together brake. I'm looking into some performance axles for the 90-93 Integras which I'm told will swap in just fine as long as I put 90-93 Integra knuckles on as well. I have them so that's what I'm doing, since I put on the rear trailing arm and disc brakes already.
Anyway, I was really only able to find Fidanza's Racing CV Axles as far as performance axles. I know there must be other companies making them for the DA Integ. So does anyone have these Fidanza Axles? I know they make bad *** Flywheels and that's why I have one of those, but how are they at making axles? Or should I go for another company? I did notice that Raxles makes a hybrid axle exactly for my 90 Civic w/ZC tranny set up. Are they any good? Then I wouldn't have to do the front Integ knuckle swap.
Any help would be great.
Oh and I did do a search for these Fidanza CV Axles on HT and nothing came up, so don't be a dick cuz I at least tried.
Thanks.
Later, PDX
Thanks.
Later, PDX
Hey Dude,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">you shouldn't have to swap integra hubs to use 90-93 non ABS integra axles. you might have to remove the small dust rings on the inner hub or the axle will bind.</TD></TR></TABLE>
Okay so my car has a JDM ZC tranny with intermitten shaft. Right now I have two passenger side Civic axles with ZC inner CV joints. I have stock Civic hubs and knuckles as well.
So you're saying that 90-93 Integra Axles will fit in my Civic hubs, but they're just a little too long so to avoid binding I need to remove the dust rings.
I thought that the hub on the Civic and the hub on the Integra were different, so I either have to swap knuckles or I have to make another hybrid axle with either an Integra/ZC Inner CV joint and civic axle or Integra axle and Civic outer CV joint. Am I right here or are you certain that the Civic and Integra Hubs are the same.
Thanks for the help.
Later, PDX
Later, PDX
h22civ
Nov 16, 2020 07:09 AM
prostreetonline
Jul 7, 2006 04:13 PM
