most common leak
Old Jul 15, 2005 | 09:43 PM
G2_Fella's Avatar
Default most common leak
i'm leaking oil on the opposite side of the oil pan. so what would be the most common leak coming from there? thanx.
Old Jul 15, 2005 | 10:00 PM
crx90rcr's Avatar
Default Re: most common leak (G2_Fella)
more detials in were ur leak is
is it trans fluid? or engine oil ?
Old Jul 15, 2005 | 10:10 PM
G2_Fella's Avatar
Default Re: most common leak (crx90rcr)
i'm not sure what it is. i haven't have time to clean it and check it. but what would be the most common leak.
Old Jul 15, 2005 | 10:15 PM
CRX_1.8T's Avatar
What exactly do you mean by "opposite side of the oil pan?" As in the passenger side of the pan?
Old Jul 15, 2005 | 10:16 PM
crx90rcr's Avatar
Default Re: most common leak (CRX_1.8T)
yea like is it even by the oil pan or is it by ur muffler or by what who cares if its alte go look im confussed now
Old Jul 15, 2005 | 10:54 PM
suspendedHatch's Avatar
If it's coming from the crank pulley, it could be the crank seal, the cam seal, or the valve cover gasket. I hope it's not your head gasket. Unless of course it's the oil pan gasket.
G2_Fella's Avatar
ok its on the passenger side.
Old Jul 15, 2005 | 10:58 PM
CRX_1.8T's Avatar
I say jack your car up and see where the oil is dripping from. Make sure your pan gasket isn't pinched or anything, or just plain worn out. Maybe remove the pan and replace the gasket, they are pretty cheap anyways.
Just make sure you wipe all of the oil off of the block and the pan before putting everything back together, otherwise that **** will leak right away again. I figured that out the hard way. Damn it LOL
Old Jul 15, 2005 | 11:05 PM
headhunter's Avatar
well i am in sort of the same situation as you right now. i just replace my oil pan gasket on my 90 integra. turns out the gasket was in need of replacement anyways, but that wasn't the major cause of my leak. this sensor right next to my oil filter is squirting oil from this wire that attaches to the sensor. i'm assuming its the oil pressure sensor. anybody know how this sensor could be leaking? i dont recall ever touching it. anyways, check by the oil filter and look at this sensor. i jacked my car up and ran the engine and looked under there. thats how i found out about my leak.
Old Jul 15, 2005 | 11:12 PM
civicrexsi's Avatar
Last time i looked... the opposite of the oil pan was... the valve cover i think... that's a pretty common leak... bout 15 bucks for the gasket
Old Jul 15, 2005 | 11:28 PM
G2_Fella's Avatar
Default Re: most common leak (civicrexsi)
good heads up guys. this weekend i probably go get some tan, swimming and watch beautiful babes @ the beach. just don't feel like getting dirty . i'll probably do this sometime in the weekdays. i'll do what you guys told me to do.
Old Jul 15, 2005 | 11:36 PM
CRX_1.8T's Avatar
If you havn't already, pick up a Helm's manual for your car. You will be very pleased that you did.
Old Jul 16, 2005 | 02:59 AM
Twilight's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx90rcr &raquo;</TD></TR><TR><TD CLASS="quote">more detials in were ur leak is
is it trans fluid? or engine oil ?</TD></TR></TABLE>
To be more exact. Where is it coming from? Because in Hondas there can be same oil in engine and transmission.
Old Jul 16, 2005 | 06:53 AM
crx90rcr's Avatar
Default Re: most common leak (Twilight)
thats y i asked
Jon Petersen
25
Mar 2, 2019 08:11 PM
94 IntegraLS
May 7, 2013 11:42 AM
90AcuraIntegra04
Jun 1, 2005 12:40 AM
mf RENO
Aug 31, 2004 11:06 AM
Rhetoric
Aug 17, 2003 12:34 PM
