Constant power wire problem...
I tried to install my deck in my EG today which had no deck there before. To get right down to it, I have no constant power signal. There is no constant power at the clock either, which runs off the same constant power signal. I haven't had a chance to check all the fuses yet, but the clock worked before I was ******* around with the wiring today. I pulled the radio fuse before I started, but I should have unplugged the battery.
Anyways, does the constant power wire go through a fuse in the fuse box or under the hood? Or not at all maybe? (I need a Helms for this thing bad)
