distributor for b16a
Old Jul 15, 2005 | 06:57 PM
solo303's Avatar
Default distributor for b16a
what kind of distrbutor should i get??? from what car??? integra/civic??
Old Jul 15, 2005 | 07:05 PM
Bunger's Avatar
Default Re: distributor for b16a (solo303)
Which OBD are you running?
Old Jul 15, 2005 | 07:58 PM
Immanuel's Avatar
Default Re: distributor for b16a (Bunger)
94-97 Del SOl VTEC should work well , someone correct me if Iam wrong.
Old Jul 15, 2005 | 08:04 PM
FlatlineEF9's Avatar
Default Re: distributor for b16a (1.6 DOHC ED9)
If youre OBD0 just go to distributor king. They have an online website. They have OBD1 and 2 also. JDM distributors, no core.
Old Jul 15, 2005 | 08:11 PM
solo303's Avatar
Default Re: distributor for b16a (FlatlineEF9)
thanks for the info...I'm running JDM b16a obd1...i bought a 91 LS integ and it didn't fit but it has the right design, the mounts are just a little narrow from the jdm mounts, so i returned the LS...the del sol vtec has a different distributor set up as far as mounting so that's no good...I'm thinking about a 93 teg gsr.....but thanks for the information...i really appreciate that...but if you have any more info to share, please do...THANKS!!
Old Jul 15, 2005 | 09:52 PM
NikoZai's Avatar
http://www.rywire.com/obd1diz.shtml
This is correct for your engine. The OBD0 dizzy wouldn't have run your engine even if it did mount.
<U>Rule of thumb.</U>
non-OBD ECU (aka OBD0) uses non-OBD Distributor.
OBD1 or 2 ECU (obd compatible) uses OBD1 or 2 Distributor.
The Del-sol VTEC model's engine matches your engine exactly. It has to work.
The B18c GSR engine's distributor matches your distributor.
The B17 GSR DOES NOT Match your distributor.
Search for TD-44U. Nothing else, not car body style.. just the right part #.. all you need. Thats it. TD-44U
(yeah other models work but lets not get complex, this is what you need. get it.)
Old Jul 16, 2005 | 01:13 AM
michael O's Avatar
Default Re: distributor for b16a (NikoZai)
On my first gen jdm b16a obd1 the del sol vtec worked...
Old Jul 16, 2005 | 05:46 AM
solo303's Avatar
Default Re: distributor for b16a (michaelOlson)
It can't be the delsol dist because the wire harness that goes around the coil has a square connector whereas mine is round. The only one that'll match is from a 91 integ LS, but unfortunately when mounting it onto the motor, the 3 mounting bracket is just slight shorter so it didn't fit. Maybe I'll just have to order from dist king like what FLatline said. I'll continue looking...
Old Jul 16, 2005 | 08:34 AM
solo303's Avatar
Correction...I'm running OBD0...
Silversubie
Jul 22, 2015 12:57 PM
ImThatGuy
Dec 3, 2004 05:05 PM
TheHatchHog
11
May 11, 2003 01:20 PM
TheKid
Jun 20, 2002 11:23 PM
VTECVillain
Dec 21, 2001 09:23 AM
