Crx obd1 conversion harness...will i have to touch resistor box for my dsm 450's
Old Jul 15, 2005 | 05:28 PM
hotimportcrx's Avatar
Default Crx obd1 conversion harness...will i have to touch resistor box for my dsm 450's
i have a crx b16 turbo...and if i switch to obd1 on a p28 using an obd0-obd1 conversion harness will i have to rewire my resistor box because i have dsm 450cc injectors installed witch need the resistor box....or can i just leave the obd0 resistor box as is and just plug my new conversion harness and ecu in and not have to touch the resistor box
Old Jul 15, 2005 | 06:27 PM
lightcrx's Avatar
yes, you can use your existing box.
-joseph
Old Jul 15, 2005 | 06:32 PM
HamiltonRex's Avatar
Default Re: (lightcrx)
correct. Match your injectors with resistor box if needed. OBD series is irelvant
Old Jul 15, 2005 | 10:01 PM
NikoZai's Avatar
Default Re: (HamiltonRex)
Excellent people know their stuff.
And here's everything you need to convert it.
http://www.rywire.com/sitob161.shtml
We sell the 4-wire O2 sensors (but you'll probably be using wide-band) and the TD-44U distributor as well
RudeLude
Apr 22, 2006 07:36 AM
Lissav
Nov 12, 2005 11:52 PM
my crx is rhd
Dec 29, 2004 09:13 AM
JDMCivicEF9
19
Sep 6, 2003 11:00 AM
SteveeeO
Mar 3, 2003 07:38 PM
