Wrinkle Paint Prep Question
I am picking up a new car on Monday & I got a CAI for it in the mail today, I plan on painting the intake w/ black wrinkle paint. Obviously I'll need to sand down the finish before I paint, but will I need to prime it before I paint? TIA
More than likely the CAI tubing will be metal so there is a need to sand down slightly the pipe. After that I always prime most of what I am painting because it helps to smooth the final coat and typically promotes adhesion. You could go with a metal adhesive promoter primer that helps out a ton, I know when I painted my intake some parts of the paint were removed easily with a slight rub so I redid it with adhesive promoter and shes beautiful
The other thing I did was tape off the holes/bungs that jut out as to not clog them or compromise any fitting issues.
Hope that helps.
.The other thing I did was tape off the holes/bungs that jut out as to not clog them or compromise any fitting issues.
Hope that helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">More than likely the CAI tubing will be metal so there is a need to sand down slightly the pipe. After that I always prime most of what I am painting because it helps to smooth the final coat and typically promotes adhesion. You could go with a metal adhesive promoter primer that helps out a ton, I know when I painted my intake some parts of the paint were removed easily with a slight rub so I redid it with adhesive promoter and shes beautiful
Hope that helps.</TD></TR></TABLE>
Thank you my friend
That was pretty much what I had in mind, but I was not aware that there was a metal adhesive primer. I'll have to source some of that this weekend. I wanted to paint it w/ teh wrinkle paint b/c I figured that it would give it more of a hint of an OEM touch ya know?
Thank you my friend
nah you don't need any primer man,
just follow the directions on the can and you'll be fine.
i'm a wrinkle paint freak,
just sand it down if its a glossy intake tube..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ_SaNdOz »</TD></TR><TR><TD CLASS="quote">
Thank you my friend
That was pretty much what I had in mind, but I was not aware that there was a metal adhesive primer. I'll have to source some of that this weekend. I wanted to paint it w/ teh wrinkle paint b/c I figured that it would give it more of a hint of an OEM touch ya know?</TD></TR></TABLE>
Yea I can see the oem touch but I just painted mine satin black and it looked great! There is adhesion promoter and it works for plastics, metal etc. GL with the project and post pics when you're done
Thank you my friend
That was pretty much what I had in mind, but I was not aware that there was a metal adhesive primer. I'll have to source some of that this weekend. I wanted to paint it w/ teh wrinkle paint b/c I figured that it would give it more of a hint of an OEM touch ya know?</TD></TR></TABLE>Yea I can see the oem touch but I just painted mine satin black and it looked great! There is adhesion promoter and it works for plastics, metal etc. GL with the project and post pics when you're done
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken »</TD></TR><TR><TD CLASS="quote">Yea I can see the oem touch but I just painted mine satin black and it looked great! There is adhesion promoter and it works for plastics, metal etc. GL with the project and post pics when you're done
.</TD></TR></TABLE>
got a pic ?
.</TD></TR></TABLE>got a pic ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio »</TD></TR><TR><TD CLASS="quote">
got a pic ?</TD></TR></TABLE>
I can snap one when I get home; I did it on my accord.
