AEM fuel filter
Old Jul 15, 2005 | 01:28 PM
ochsy03's Avatar
Default AEM fuel filter
i got one for my 99 civic si and the guy whos buildin my motor said something about theres no screw on the top of it so hook up the oil line to....do i need extra parts??
Old Jul 15, 2005 | 01:34 PM
JDM-97CX's Avatar
Default Re: AEM fuel filter (ochsy03)
You need a banjo bolt and two washers for it.
Marauder's Avatar
Why would you hook an oil like up to a fuel filter?
Old Jul 15, 2005 | 01:37 PM
JDM-97CX's Avatar
Default Re: AEM fuel filter (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Why would you hook an oil like up to a fuel filter?</TD></TR></TABLE>
Im thinkin he meant fuel line
Old Jul 15, 2005 | 01:44 PM
Marauder's Avatar
Default Re: AEM fuel filter (JDM-97CX)
Its meant to reuse the factory bolt and you just need two new sealing washers.
Old Jul 15, 2005 | 03:31 PM
ochsy03's Avatar
where could i get a banjo bolt?
Old Jul 15, 2005 | 03:32 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ochsy03 &raquo;</TD></TR><TR><TD CLASS="quote">where could i get a banjo bolt?</TD></TR></TABLE>
Here is a hint, it is on the top of your stock filter. And then all you need is two washers.
Old Jul 15, 2005 | 04:20 PM
ochsy03's Avatar
no no...my stock nut isnt threaded the same as my fuel filter so it wont screw in
Old Jul 15, 2005 | 09:51 PM
confidence's Avatar
i have one and mine stock filter harware matched just fine. dunno whats wrong with yours. you could find out what the tread size and pitch is then get an Earl's (or anyone AN line makers) adaptor and run AN line from there to the fuel rail. an expensive but pretty solution
Old Jul 16, 2005 | 08:23 AM
ochsy03's Avatar
Default Re: AEM fuel filter (snail)
im gonna check the part # on the fuel filter make sure its the right #
94DOHCDELSOL
16
Jan 18, 2011 04:11 PM
.Hatches.
Mar 17, 2008 05:53 PM
AndrePerras
May 26, 2007 11:03 AM
namja9487
Jul 23, 2004 08:41 AM
WayneGro
Oct 24, 2003 04:58 AM
