Need some help with new motor
Old Jul 15, 2005 | 01:10 PM
LSVtechnologytur...'s Avatar
Default Need some help with new motor
First let me give you some background:
I just put a freshly built lsvtec motor in my car, ready for boost. I have arias pistons, eagle rods, stock sleeves bored .20 over. Stock b16 head with new springs and stem seals.
Start it up for the first time and it runs but it makes a wired knocking sound really randomly..
So i take my car to get tuned a few days ago(hoping i would be able to get it running long enough to pinpoint the problem) and its running pretty well.. get the idle smoothed out but as soon as its revved to ~ 2 - 2.5k rpm the knocking sound comes back. It doesn't fade in or out as the motor is revved up to that point .. its just like on or off. But its still does not have any pattern to it.
-edit- sounds like its coming from the top end
So i pull off the valve cover and check everything .. keepers, cams, run a magnet through and everything is fine. Drop the oil pan and notice a little bit of metal shavings / flakes. Now im not positive but i think some of the metal could be from drilling the oil return line for the turbo.
So I'm thinking and thinking about what the hell it could be and i come up with the idea that maybe ( not even sure if its possible) the vtec solinoide is stuck open and as the motor creates higher oil pressure it starts to randomly engage vtec.
So does anyone know if this is possible? What should i check next? does anyone know what the hell is wrong
Thanks in advance for any help
al
Old Jul 15, 2005 | 02:59 PM
PrettyLude's Avatar
you positive the shavings are from the oil return? you sure its not the bearings?
Old Jul 15, 2005 | 05:19 PM
Default Re: (PrettyLude)
not positive, but I don't think its bearing related because it's not a constant noise.
Old Jul 15, 2005 | 07:04 PM
sickerhatch's Avatar
Default Re: (vtec'n)
is it more of a ticking than a knocking? if it is maybe its your lma's.
Old Jul 16, 2005 | 06:37 AM
Default Re: (sickerhatch)
lma's?
:edit: just searched to find out what they are... and im going to check them now, thanks for the idea/help
Modified by vtec'n at 12:33 PM 7/16/2005
Old Jul 16, 2005 | 08:54 AM
I think the lma's might be the problem because a couple of them seem to stick. Can anyone describe how loud a bad LMA is? Like a really loud / sporadic valve tick?
tonydize21
Jun 11, 2011 08:28 PM
550whpcivic
Sep 16, 2010 06:37 AM
( o )( o )
15
Oct 14, 2005 10:40 AM
sleepycivichb
11
Jun 25, 2005 08:37 AM
intekragsr
Apr 17, 2003 05:25 PM
