General preventative maintenance things
Old Jul 15, 2005 | 11:33 AM
B18EG6's Avatar
Default General preventative maintenance things
Hello--
MY car has been down for almost three years. Im rebuilding the motor so everything in there is fresh.
In terms of seals, and other maintenance, what should I do? My tranny has been sitting in my garage, it has a small spiderweb in the bell housing lol.. other than removing it, should I take it apart to inspect it?
What other things should I look into?
edit - New throw out bearing needed? New pilot bearing needed? New input shaft bearing needed? just a few of the things that popped into my head. Should I worry about these?
Modified by B18EG6 at 5:38 PM 7/19/2005
Old Jul 15, 2005 | 03:00 PM
PrettyLude's Avatar
put some fresh oil in your tranny
Old Jul 15, 2005 | 04:08 PM
B18EG6's Avatar
Default Re: (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">put some fresh oil in your tranny</TD></TR></TABLE>
yeh I plan on doing that
I guess I should be a little more specific. Should I open the case of the tranny and change any bearings or anything in there, while its off the car? Ill take some pics of the clutch and see if I need anything new for that also.
Im getting a bottom end gasket kit also.
do I need to drain the gas and change it?
anything else?
Old Jul 18, 2005 | 06:53 AM
B18EG6's Avatar
Default Re: (B18EG6)
anymore opinions?
sanman000719
Transmission & Drivetrain
Feb 7, 2010 04:34 PM
tigueremalo
28
May 13, 2006 03:32 PM
eg4door
Jun 7, 2005 07:37 PM
Jason C SBB
Jan 25, 2005 10:42 AM
