Need Help! Did I buy the wrong bearings?
Old Jul 15, 2005 | 07:41 AM
Squirtle's Avatar
Default Need Help! Did I buy the wrong bearings?
Tried searching but haven't been able to the find the answer I am looking for.
I puchased a OBX LSD for my YS1 jdm cable transmission and installed some brand new 2001 integra type r ball type carrier bearings for it (part#91005-P80-E31 ) (80mm*40mm*19.5). It seems that I purchased the wrong bearings due to the fact that the transmission housing does not close and differential does not sit to the proper height. I had the bearings pressed down. So I know the bearings are properly seat. My question is did I buy the wrong bearings if so which bearings would I need for my particular setup. All replies will be appreciated.
Old Jul 15, 2005 | 07:27 PM
Squirtle's Avatar
Anyone please help!
Old Jul 16, 2005 | 08:53 PM
Squirtle's Avatar
Still can't get it to sit. Someone please!
Old Oct 17, 2005 | 11:03 PM
rebo0t's Avatar
Default Re: (Squirtle)
I have the same problem. Took it to a transmission shop and turns out that the bearings we have are too high. 1.5mm too high on each bearing. So you end up with a 3mm gap, if you try to tighten it the casing WILL crack. This is what happened to me. I am still currently trying to figure out which bearing I need. So far, 91005-P80-003 is from a GS-R and it measures 40X80X17. I think this one might work. Also the 00 Civic Si's are 40x80x18.
Old Oct 19, 2005 | 09:51 AM
rebo0t's Avatar
Default Re: (rebo0t)
Ok, got my transmission back together. The bearings we need are 80x40x18. You can get these from the 00 Civic Si, or from 95+ Integra LS. They dropped right in.
coot_er
Nov 10, 2009 09:25 PM
TB123
Transmission & Drivetrain
11
Apr 12, 2009 11:06 PM
MeathooK
Jul 14, 2008 06:23 AM
1SlowSi
Mar 7, 2005 07:32 AM
burnicq
Apr 20, 2002 09:34 PM
