obd I conversion to obd 0
what in gods name do i have to do to convert my sir2 (obd1) into my 89 crx (obd 0) im sure you guys know that im the ignorant one asking but i have no idea what so ever to do. plz plz help im pulling out my hair over this ****
Checkout http://www.rywire.com
If thats a DX we can perform a DPFI to MPFI conversion on the engine harness specificly for that engine. You'll have all the sensors you need and it will be wired up to a pigtail run from the OBD0 to OBD1 ECU Jumper harness.
Here's the swap you want. if you're DPFI
http://www.rywire.com/dxtob161.shtml
Here's what you need if you're HF/Si . Since it's an OBD1 engine, you may have your fan switch on your waterneck instead of the back of the block. (round 2 pin connector vs. 2 pin slip on connector) So you'll probably want to send us your harness, for $240 we will make your harness specifically for the sensors on that engine.
http://www.rywire.com/sitob161.shtml
My phone # is on the rywire.com site
give me a call.
give me a call.
thank you very very much for that information i have a d16z6 head with a stage two cam maybe we could do some trading or something? umm i will more than likely call you later on in the day. again thank you.
faSHOwidIT
Jun 14, 2005 12:10 PM
