150k LS w/turbo
Old Feb 16, 2002 | 06:59 PM
vtecsiqt's Avatar
Default 150k LS w/turbo
do you think my 150,000 mi ls could handle 5-7 psi, did a leak down test 7% leakage on 2 cylinders and 10% leakage on the other 2. my mechanic said those for very good numbers for the miles
Old Feb 16, 2002 | 08:29 PM
Ri5e's Avatar
Default Re: 150k LS w/turbo (vtecsiqt)
You could but you won't be getting as much power compared to another turbo LS with 1% leakdown or something.
My advice would be to put in new piston rings..or just get pistons/rods/rings all at once while you have the block worked on.
Old Feb 16, 2002 | 10:16 PM
mercury's Avatar
New User
Those are pretty good numbers for the mileage, but did you mention to your mechanic that you wanted to go turbo on the engine?
Old Feb 16, 2002 | 10:30 PM
SIK IN DA HED's Avatar
New User
Default Re: 150k LS w/turbo (mercury)
i got 129,000+ miles on my LS and im still boostin 5lbs. just be good to your car... dont over-do it and it should be fine. im pretty sure your leakdown tests are way better than mine. my engine has been abused. im going to need a new one soon. go for it... turbo is cool. your motor should be able to take it. provided that you tune it and maintain it daily.
killablaze
Oct 7, 2005 04:06 PM
xfrankx
Aug 18, 2005 06:21 PM
96 honda hatch
Jan 5, 2005 09:46 PM
integra81
Oct 29, 2001 12:27 PM
