Ok, the side marker install (pics)
Old Jul 15, 2005 | 04:30 AM
CBURKE's Avatar
Default Ok, the side marker install (pics)
ok I seen some people ask how to do this, well here you go.
Here is the car that i am working on (project)
I measured mine 3 inches from the door and 4 inches from the trim.
Yumm, Honda thanks (Password JDM)
Now, next I drill holes so it will make it easy er to get the cutter in.
Don't mind the sloppy cuts. The bit was getting bad. Now you can kinda see that the one end it flat not oval, that is because if you use these markers they have a little lip that locks it into place.
Next I hook it up to the front blinkers. 2 reasons, A: there is 2 wires you can just hook both up and B: they will only come on when the blinker is on.
You may not wanna be cheep and get the harness, it did make this a little easy er.
ok there you go, like my kids say ( Taaadaaa)
I really hope this helps someone out.
Old Jul 15, 2005 | 05:35 AM
manson's Avatar
Default Re: Ok, the side marker install (CBURKE)
something i'm going to look into doing myself. looks great.
Old Jul 15, 2005 | 05:40 AM
KingKhong's Avatar
looks good but you might want to put something on the exposed metal something rust proof.
Old Jul 15, 2005 | 05:47 AM
UsDm_Junky's Avatar
agreed
Old Jul 15, 2005 | 06:28 AM
crxgator's Avatar
Default Re: (RegatoneSucks)
looks good, but you know that those are for an EG right?
Old Jul 15, 2005 | 06:30 AM
CBURKE's Avatar
NO, there integra lights, and i know about the rust i'm getting the car painted so i left that out for now.
Old Jul 15, 2005 | 07:13 AM
DADADAAAMN's Avatar
Default Re: (CBURKE)
interesting.. imma have to go n invest in one of those..
Old Jul 15, 2005 | 07:18 AM
SiR Inspired ED7's Avatar
No!!! lol, those are Integra Side Marker Lights...
Ef8 ones look like:
Old Jul 15, 2005 | 07:53 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Ok, the side marker install (88 Crx Si)
What holds the light in place?
Old Jul 15, 2005 | 08:13 AM
pos_ef8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88 Crx Si &raquo;</TD></TR><TR><TD CLASS="quote">No!!! lol, those are Integra Side Marker Lights...
Ef8 ones look like: </TD></TR></TABLE>
EJ2-Fluffy's Avatar
Default Re: Ok, the side marker install (goforbroke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke &raquo;</TD></TR><TR><TD CLASS="quote">What holds the light in place?</TD></TR></TABLE>
held in place by a clip on the sidemarker.
Old Jul 15, 2005 | 08:25 AM
dh's Avatar
dh
Default Re: Ok, the side marker install (CRX-Fluffy)
Eh doesn't rreally matter to me. Still looks good, and does it's purpose.
Old Jul 15, 2005 | 08:27 AM
EJ1 wilcox's Avatar
Default Re: Ok, the side marker install (ILOVEMYEF8)
Who cares if they are integra or civic lights?
They look good
Old Jul 15, 2005 | 08:28 AM
crxgator's Avatar
they are EG...
http://passwordjdm.com/product...D=248
Old Jul 15, 2005 | 08:36 AM
Its me DUB's Avatar
Default Re: Ok, the side marker install (crxgator)
Nice write up. I have had my sidemarkers sitting in the garage for about a month. I guess I was just worried that I'd mess up my fender. Now looking at those cuts...it doesn't look like it has to be perfect
Thanks for the write-up! Plan on doing it this weekend or next and this should help...
by the way, what color you painting it? I have the same color and offended that you're not keeping the metallic blue I love the metallic blue, but then again...blue is the best color evar!
Old Jul 15, 2005 | 08:37 AM
CBURKE's Avatar
Well I first got them for my integ. The web sit said for integra. Then i got the rex. I like them, and I only made this to help some people out that may be to scared to start cutting into there finder.
Old Jul 15, 2005 | 08:46 AM
Its me DUB's Avatar
Old Jul 15, 2005 | 09:07 AM
mahatma's Avatar
Default Re: Ok, the side marker install (doitdub)
I did this to my '87 HF and it was madddd easy because the fenders were plastic.
Dremel did it like a hot knife thru butter
Old Jul 15, 2005 | 09:50 AM
BiG Chris's Avatar
i know its not the place but we are on the subject of it and i i got these up for grabs
Old Jul 15, 2005 | 02:36 PM
Suck my DX's Avatar
Default Re: (BiG Chris)
not tryin to jack the thread but i installed a rear fog from an ef on my homies ej the other day...i had never done anything like that before so i was trippin before i cut it...it was actually quite easy...metal is a bit trickier but as long as u have a steady hand that **** will come out nice...btw the fog looks sick on an ej
Old Jul 15, 2005 | 02:52 PM
CWBETB's Avatar
Very good write up, I could just never have the ***** to cut my fender though
Old Jul 15, 2005 | 03:25 PM
Tyson's Avatar
to anyone else who might want to try this themselves, i would recommend that you still mask off the surrounding area while cutting the hole. you will eliminate that stray mark shown at the bottom if the bit gets loose. also, use a straight edge to help cut a straighter hole and protect the surface.
Old Jul 15, 2005 | 05:07 PM
BiG Chris's Avatar
i would recomend a cutting disc on a dremel and a drum sander attachment for it. i think that would come out good and using masking take is a good point too
Old Jul 15, 2005 | 10:14 PM
ukdm crx's Avatar
Why did you put integra side markers in and not the ones that are supposed to be in it.
Old Jul 15, 2005 | 11:04 PM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CBURKE &raquo;</TD></TR><TR><TD CLASS="quote">NO, there integra lights</TD></TR></TABLE>
its they're. jesus.
and I tapped into the side marker for my pwr/grnd and prefer it that way.
mine are always on and then switch to flash with the signals.
just an FYI.
