ARP head studs, difference between LS/vtec kit, b16a and b18c...
Old Jul 15, 2005 | 03:01 AM
Garrett's Avatar
Default ARP head studs, difference between LS/vtec kit, b16a and b18c...
Yesterday at the shop we compare ARP b16a studs and b18c studs
they look exactly the same
we are sure that it'S the same for LS/vtec ARP head studs kits (the kit is more expensive than GSR/b16a kit)
someone had more infos about it?
Old Jul 15, 2005 | 08:49 AM
Garrett's Avatar
Default Re: ARP head studs, difference between LS/vtec kit, b16a and b18c... (Garrett)
I'M sure someone know the answer
Old Jul 15, 2005 | 11:56 AM
Suck my DX's Avatar
b16 and gsr head studs are not the same...try using b16 head studs in a gsr block and see what happens...if they were interchangeable they would market them as fitting both models...
Old Jul 15, 2005 | 10:55 PM
Toxidomask's Avatar
Default Re: ARP head studs, difference between LS/vtec kit, b16a and b18c... (Suck my DX)
18s are suppose to be longer. compaired to the 16s.
Old Jul 16, 2005 | 12:01 AM
michael O's Avatar
Default Re: ARP head studs, difference between LS/vtec kit, b16a and b18c... (Toxidomask)
Well when I look at mine they're like 2+cm longers
Old Jul 16, 2005 | 03:30 AM
Garrett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">b16 and gsr head studs are not the same...try using b16 head studs in a gsr block and see what happens...if they were interchangeable they would market them as fitting both models...</TD></TR></TABLE>
we compare ARP b16 to OEM honda GSR and the lenght is the same when installed into the block
Old Jul 16, 2005 | 10:44 AM
Rod.'s Avatar
use the gsr for ls/vtec
Old Jul 18, 2005 | 05:32 PM
Garrett's Avatar
Default Re: ARP head studs, difference between LS/vtec kit, b16a and b18c... (Rod.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod. &raquo;</TD></TR><TR><TD CLASS="quote">use the gsr for ls/vtec</TD></TR></TABLE>
same as the b20b with b16a head as ARP said on the application list?
Old Jul 20, 2005 | 03:08 PM
Toxidomask's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garrett &raquo;</TD></TR><TR><TD CLASS="quote">
we compare ARP b16 to OEM honda GSR and the lenght is the same when installed into the block </TD></TR></TABLE>
You cant compair the lenght of a head stud to OEM bolts, its not the same.
Old Jul 20, 2005 | 03:13 PM
Suck my DX's Avatar
do not listen to this guy...he made another post saying that he compared b16 to gsr headstuds and they were the same...THEY ARE NOT THE SAME...if they were the same why would arp advertise them seperately?
Old Jul 20, 2005 | 09:07 PM
TheLastSpartan's Avatar
THEY ARE NOT THE SAME.</TD></TR></TABLE>
True. The only ones that ARE the same is the GSR studs and the LS/Vtec or B20/Vtec studs. Rest are different.
Old Jul 21, 2005 | 04:31 AM
Garrett's Avatar
Default Re: ARP head studs, difference between LS/vtec kit, b16a and b18c... (TheLastSpartan)
Thanks alot
We'll call ARP GSR to compare to ARP B16
projectef
20
Mar 5, 2022 08:47 PM
dai-18t
Sep 18, 2009 07:25 AM
SPOOLINmatt
Apr 8, 2005 12:40 PM
B18PoweredCivic
Apr 26, 2003 05:34 PM
paulzy
May 21, 2002 12:33 PM
