RSX n S2000 steering wheel in EK
Old Jul 15, 2005 | 02:24 AM
wickedEM1's Avatar
Default RSX n S2000 steering wheel in EK
are both RSX n S2000 steering wheels plug n play for 96-00 civics...does cruise control still work?
Old Jul 15, 2005 | 02:39 AM
13link EG's Avatar
Default Re: RSX n S2000 steering wheel in EK (wickedEM1)
you have been around for awhile search
Old Jul 15, 2005 | 03:22 AM
The_Todd's Avatar
Farts in the shower
Default Re: RSX n S2000 steering wheel in EK (13link EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13link EG &raquo;</TD></TR><TR><TD CLASS="quote">you have been around for awhile search</TD></TR></TABLE>
Instead of just telling people to search how about you provide them with a link and THEN tell them to search.
https://honda-tech.com/zerothread?id=1276271 &lt;==s2k and rsk are compatible with ek's and integras are interchangeble with eg's
https://honda-tech.com/zerothread?id=1260752 &lt;==rsx installation on an ek
But yes, search is your friend .
Old Jul 15, 2005 | 03:26 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: RSX n S2000 steering wheel in EK (.ken)
hooo weee!
Old Jul 15, 2005 | 10:58 AM
wickedEM1's Avatar
Default Re: RSX n S2000 steering wheel in EK (litterbox)
so does the airbag work on s2k steering wheels?
Old Jul 15, 2005 | 11:34 AM
ErrDizzle's Avatar
I know someone who had a s2k wheel is his EK and he said everything worked, including the airbag.
Old Jul 15, 2005 | 12:00 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wickedEM1 &raquo;</TD></TR><TR><TD CLASS="quote">so does the airbag work on s2k steering wheels?</TD></TR></TABLE>
Old Jul 15, 2005 | 01:57 PM
Earthworm Jim's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">
This is tight, you can do the same swap into an EG right?
Old Jul 15, 2005 | 03:01 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: RSX n S2000 steering wheel in EK (TheGeneral)
CTR steering wheel
Old Jul 15, 2005 | 03:05 PM
JDM-97CX's Avatar
Default Re: RSX n S2000 steering wheel in EK (BrokeAssPinoy)
The JDM RSX wheel and the S2k wheel do not fit in EGs. And if you click the back button at the top left hand of the screen and then scroll down about half way you will see another post just like this one.
Old Jul 15, 2005 | 03:06 PM
psi2high's Avatar
Default Re: RSX n S2000 steering wheel in EK (BlueIntegraBoy)
every thing should work fine as long as the wiring is hooked up
Old Jul 15, 2005 | 04:29 PM
djSALIX's Avatar
Modified by djSALIX at 9:27 PM 7/15/2005
Old Jul 15, 2005 | 04:38 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGeneral &raquo;</TD></TR><TR><TD CLASS="quote">
This is tight, you can do the same swap into an EG right?</TD></TR></TABLE>
No...if you read my post you would know this just fyi .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jul 15, 2005 | 05:19 PM
EKCRX-Ihadastupidusername's Avatar
That pic is the gayness, wheel doesn't match anything else at all.
Old Jul 15, 2005 | 07:27 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diegoaccord &raquo;</TD></TR><TR><TD CLASS="quote">That pic is the gayness, wheel doesn't match anything else at all.</TD></TR></TABLE>
Check
Old Jul 15, 2005 | 08:10 PM
Si Shane's Avatar
i'm glad i wasn't the only one freaking out about how ugly it looked
Old Jul 16, 2005 | 12:26 AM
built562's Avatar
Default Re: RSX n S2000 steering wheel in EK (Si Shane)
^^^^^ so true the rasx wheel lookes like a$$, on the other hand the s2k wheel looks better. but just stick with irt/ctr wheel with the airbag. bolt on and looks better
Sp00nFed EM1
18
Feb 18, 2008 02:17 PM
MilanoRed EG6
12
Aug 27, 2006 06:29 PM
dave1234
Jul 3, 2006 01:07 PM
mikeweb
May 7, 2005 12:59 PM
JDM-FREAK
15
Mar 9, 2005 09:39 AM
