Traction
Old Jul 14, 2005 | 11:28 PM
bbartnick2005's Avatar
Default Traction
hey whats fellow imports. im having a traction problem wit my 2000 civic si. everytime i wholeshot at 3500 rpms my tires spin way too much for the rpm im at. im wondering whats up and if nebody knows y its happening. neways sumone let me know pleaze, aprreciate it.
Old Jul 14, 2005 | 11:29 PM
Hatch It's Avatar
Default Re: Traction (bbartnick2005)
Itz cause mad vtec kickin in yo....makes yo caa spin like m@d
on a serious note:
better tires or maybe aftermarket motor mounts
Old Jul 15, 2005 | 12:30 AM
sicky's Avatar
grammer nawzi
A ****-load of things can cause that. 1. Try launching at a lower RPM (2600 works for me). 2. Decrease tire pressure (if the tires are too full wheels won't get optimal traction or bite on the surface). 3. If you're racing on the shitty streets of MI . . .well, there's that answer. 4. Get better suspension.
Old Jul 15, 2005 | 12:33 AM
RangerDan's Avatar
Default Re: Traction (sicky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">A ****-load of things can cause that. 1. Try launching at a lower RPM (2600 works for me). 2. Decrease tire pressure (if the tires are too full wheels won't get optimal traction or bite on the surface). 3. If you're racing on the shitty streets of MI . . .well, there's that answer. 4. Get better suspension.</TD></TR></TABLE>
yep all that plus try feathering the clutch abit. With decent tires you should be able to launch around 6000-6500 rpm.
Old Jul 15, 2005 | 02:10 AM
Kyles ej1's Avatar
Default Re: Traction (RangerDan)
yea dont dump the clutch unless your on slicks. feathering works best. ive revved up to 5k in my 16 when i feather it.
my guess would be your psi in the tires are too high. does it just burn rubber or does it get wheel hop?
Old Jul 15, 2005 | 04:56 AM
TurboEM1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbartnick2005 &raquo;</TD></TR><TR><TD CLASS="quote">hey whats fellow imports. im having a traction problem wit my 2000 civic si. everytime i wholeshot at 3500 rpms my tires spin way too much for the rpm im at. im wondering whats up and if nebody knows y its happening. neways sumone let me know pleaze, aprreciate it.</TD></TR></TABLE>
Get better tires, less tire pressure, and feather the clutch more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicky &raquo;</TD></TR><TR><TD CLASS="quote">A ****-load of things can cause that. 1. Try launching at a lower RPM (2600 works for me). </TD></TR></TABLE>
2600? That seems way to low. In my 99 Si about 6500rpm is where I launch. The b16 doesnt have enough low end to launch anything under 5500rpm's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan &raquo;</TD></TR><TR><TD CLASS="quote">
yep all that plus try feathering the clutch abit. With decent tires you should be able to launch around 6000-6500 rpm.</TD></TR></TABLE>
Same here
jayms
Jan 9, 2008 11:21 AM
92hatchling
Feb 15, 2006 01:54 PM
MyBigNut
Jul 4, 2003 06:54 AM
KooK
Jun 30, 2003 10:06 AM
sshaikh01
15
Jun 19, 2003 11:14 AM
