ZC mini-me question.
Old Jul 14, 2005 | 09:41 PM
1point7db2's Avatar
Default ZC mini-me question.
I have a single cam ZC. I'm about to throw on a Z6 vtec head, Has anyone done this? what kind of performance should I expect, and will there be any clearance issues with the valves and th zc pistons? The compreeson calculator says it should be like over 13:1 compression, it should run pretty strong if it works.
Old Jul 14, 2005 | 10:18 PM
4runner's Avatar
Default Re: ZC mini-me question. (h22rexguy)
im curious too
Old Jul 15, 2005 | 12:13 AM
c0nspire's Avatar
Default Re: ZC mini-me question. (88HaveFun)
shoudl be the same as putting a z6 head on a a6 block
Old Jul 15, 2005 | 12:45 AM
davens's Avatar
Default Re: ZC mini-me question. (c0nspire)
How do you figure 13:1? More like 10:1.
The sohc zc is the same as the d16a6...except for the cam. So its not like it has the high compression pm7 pistons of a dohc zc.
And the sohc zc makes 118 hp. A mini-me should make 125-130ish. So maybe a 10 hp increase. That's a lot of work/expense for 10hp.
If you were starting at 108 hp and looking at a 20hp increase, I would find it more attractive of a swap.
Old Jul 16, 2005 | 09:21 PM
1point7db2's Avatar
Default Re: ZC mini-me question. (davens)
oh i see, I thought the single cam zc had the same pistons as the dohc. So the zc cam is better than the si cam? Maybe I can throw in some pm7 pistons with the vtec head? would that give me the wild comp #'s? Thanks for the help.
Old Jul 17, 2005 | 11:12 AM
PIMPALA-SS's Avatar
have the head milled down a little.. and use a thin headgasket. that will raise the compression.
killercrx91
Nov 9, 2009 10:44 PM
bacnoonoi
16
Oct 3, 2008 08:36 AM
4door93civic
Feb 1, 2008 08:46 PM
Gant
10
Apr 29, 2004 05:26 PM
Superhatch
Sep 14, 2003 11:43 PM
