vtec kickin in too early?
Old Jul 14, 2005 | 09:28 PM
itsmeandroo's Avatar
Default vtec kickin in too early?
i know this might sound stupid but i'm new to this and im not sure if its right...i got a b16a (obd0) in my EF a couple months ago but everyones been telling me that vtec kicks in too early.i have the dx model so no tachometer but people have been estimating around 4000 rpm..is this normal or bad...if bad what could be the cause of it?? all the motor has is intake, dc sports 4-1 header, aebs intake manifold..seems like its lagging since sohc civics are either keeping up or beating me??o well i believe it is the y1 tranny. thanks for the help everyone
Modified by itsmeandroo at 11:41 PM 7/14/2005
Modified by itsmeandroo at 11:46 PM 7/14/2005
Old Jul 14, 2005 | 09:49 PM
Immanuel's Avatar
Default Re: vtec kickin in too early? (itsmeandroo)
Yours is at 4000rpm???? It should be around 5200 RPM. I have a 1st gen OBD 0 Pr3 ECU, and Vtec kicks in at 5200 RPM. Just get a Vtec controller if you want and set RPM for the VTEC yourself, but it should be around 5200 stock.
Old Jul 14, 2005 | 10:27 PM
91civicEX's Avatar
Default Re: vtec kickin in too early? (1.6 DOHC ED9)
you cant tell with no tachometer dude. does it feel like it lags when it kicks in the picks up 1000 rpm later?
EDIT: if you post up what tranny u have we might be able to tell u what speed u would be at in a particular gear at 5200 rpm and that would be the cheapest way to see when ur VTEC kicks in
Old Jul 14, 2005 | 10:49 PM
Bunger's Avatar
Default Re: vtec kickin in too early? (91civicEX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicEX &raquo;</TD></TR><TR><TD CLASS="quote">does it feel like it lags when it kicks in the picks up 1000 rpm later?</TD></TR></TABLE>
Why would he feel a lag? With stock cams you can have a smooth x-over even at 4000 rpm.
Old Jul 14, 2005 | 11:27 PM
Ch3mik's Avatar
Default Re: vtec kickin in too early? (Bunger)
nope. if it kicks in too early there is a lag. i felt it on a stock b16
Old Jul 14, 2005 | 11:31 PM
crx90rcr's Avatar
Default Re: vtec kickin in too early? (Ch3mik)
ill tell u if i ever find out how to get mine to start i have a vtec controller i dont c y i couldnt drop it to 4000 or even lower to c how it runs
Old Jul 15, 2005 | 12:12 AM
Bunger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik &raquo;</TD></TR><TR><TD CLASS="quote">nope. if it kicks in too early there is a lag. i felt it on a stock b16</TD></TR></TABLE>
Well of course there is a limit... If you're running CTR cams, then I normally set the x-over point to about 5000-5200, but I've set the x-over as low as 3300 on stock cams without any dip on the dyno.
Old Jul 15, 2005 | 01:26 AM
PINEAPPLE's Avatar
i agree with 91 civicex. first get a tach or something to read out engine speed to find out where it really kicks in.
Old Jul 15, 2005 | 01:48 AM
Twilight's Avatar
Default Re: (PINEAPPLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmeandroo &raquo;</TD></TR><TR><TD CLASS="quote">i have the dx model so no tachometer but people have been estimating around 4000 rpm.</TD></TR></TABLE>
Get a tachometer somewhere. A B16 swap w/o tach, wierd.
No human can tell accurate rpm by just hearing it.
Old Jul 15, 2005 | 04:36 AM
Autoworks's Avatar
Default Re: (Twilight)
My pwo had the xover at 5200, when I swapped to my now PR3 it dropped it down to 4500. Without a tach you wouldn;t be able to accurately tell
redline09
Jan 23, 2010 06:11 PM
fryman
Sep 28, 2008 02:32 PM
asianeric
Dec 12, 2006 08:39 AM
goodwinesi
May 9, 2004 03:22 AM
hman09
Feb 22, 2004 08:50 AM
