obd1 b16 into 1999 obd2 b16 civic si
Old Jul 14, 2005 | 07:01 PM
spidermancivic's Avatar
Default obd1 b16 into 1999 obd2 b16 civic si
i blew my b16a2 on my 99 si. need a quick replacement longblock fast, and, ive found plenty of obd1 jdm b16a sir2s.
i know i will need to change out the crank angle for the short block, but, is that it? as for the head, im thinkin dizzy too, but, are there pinouts for this?
am i missing anything else?
TIA.
Old Jul 14, 2005 | 11:12 PM
NikoZai's Avatar
Default Re: obd1 b16 into 1999 obd2 b16 civic si (spidermancivic)
you "blew your engine" just use the new block, same bolt-ons... fan switch might be different.. i'm too tired to get into it.. but it shouldnt be a OBD conversion or anything...
Old Jul 15, 2005 | 04:38 AM
VTECVillain's Avatar
You will have to change the oil pump to OBD2 then install the crank fluctuation sensor. It would also be best to use the complete intake manifold and distributor from your stock B16A2 if possible.
Old Jul 15, 2005 | 09:21 AM
klungemonger's Avatar
Default Re: obd1 b16 into 1999 obd2 b16 civic si (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">You will have to change the oil pump to OBD2 then install the crank fluctuation sensor. It would also be best to use the complete intake manifold and distributor from your stock B16A2 if possible.</TD></TR></TABLE>
What he said!!! Whole oil pump needs swapping unless you plan to run an OBD1 ecu conversion. Otherwise the OBD1 block is good. If only the bottom end is bad on yours I'd suspect you were planning to reuse everything else from the original motor anyways like manifold, dist. etc...
wowy978
Oct 21, 2008 08:39 PM
Jason703Racing
Mar 28, 2006 07:13 PM
aw1234dude
Dec 15, 2004 06:32 PM
aw1234dude
Dec 7, 2004 12:56 AM
Ryan C
Jul 23, 2004 09:58 AM
