my 91 CRX Si in SICK! HELP
Old Jul 14, 2005 | 04:59 PM
MkivTrd's Avatar
Default my 91 CRX Si in SICK! HELP
hey guys,
new here... Well i have a 91 crx si, with 175k miles, i have NEVER had a problem with the car. Well the problem started out as a rough idle at startup/ missfire. I got gas the other day and drove 30 miles to work fine. When i got to work it started to missfire and run really rough, and would just die. So after my shift i started the car up and it ran fine. Drove 30 miles home and it was fine, 1 mile away from the house it started to missfire again. Now the car will barely run I have to keep the pedal to the floor for it even to idle. I have changed the plugs, plug wires, cap and rotor. and fuel filter. Is it possible i got bad gas? any ideas?? THANKS!
Old Jul 14, 2005 | 05:04 PM
86si's Avatar
Default Re: my 91 CRX Si in SICK! HELP (MkivTrd)
distributor maybe, its hard to say...
Old Jul 14, 2005 | 05:29 PM
MkivTrd's Avatar
Default Re: my 91 CRX Si in SICK! HELP (86si)
Ahh, almost forgot about a year ago i went to the gas station, filled up and then the car wouldnt start at all, took it to the shop and they said it was the distributor, possible it went out again?
Old Jul 14, 2005 | 05:32 PM
kulangot's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MkivTrd &raquo;</TD></TR><TR><TD CLASS="quote">Ahh, almost forgot about a year ago i went to the gas station, filled up and then the car wouldnt start at all, took it to the shop and they said it was the distributor, possible it went out again?</TD></TR></TABLE>
it is possible...
Old Jul 14, 2005 | 05:34 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Have you ever replaced the main relay?
They tend to fail when it is really hot outside...
https://honda-tech.com/zerothread?id=1307206
also see: http://autorepair.about.com/cs...a.htm
For trouble-shooting tips...
Old Jul 14, 2005 | 06:30 PM
MkivTrd's Avatar
Default Re: my 91 CRX Si in SICK! HELP (88DXCRX)
well the car will start up and run, but dies right away, if i give it gas it will run really rough, possible its the main relay?
Old Jul 14, 2005 | 06:44 PM
88DXCRX's Avatar
It is possible..
the two most common things that fail are the main relay
and the distributor/ignitor..
The ignition switch can fail with old age as well..
Any check engine lights?
Old Jul 14, 2005 | 06:48 PM
CaliforniaHighwayPatrol's Avatar
alternator...
Old Jul 15, 2005 | 09:05 PM
MkivTrd's Avatar
Old Jul 15, 2005 | 09:27 PM
bob06's Avatar
sounds sorta like mine when my distributor wiring was wrong
Old Jul 15, 2005 | 10:48 PM
MkivTrd's Avatar
so should i try and replace the main relay first?
Modified by MkivTrd at 12:05 AM 7/16/2005
Old Jul 16, 2005 | 04:30 AM
HBK's Avatar
HBK
I hear the main relay can be a bitch to get to. 9times outta 10 its the distributor for me. I've never replaed the main relay. Its definitely not the alternator, if it was then ur battery would be dead by now. Either find someone who has a dizzy to try or pick one up.
Old Jul 16, 2005 | 07:32 AM
mnhotrod2003's Avatar
HATE to say it but i had the same problem happen to mine and it turned out to be a head gasket. smell your coolant can u smell exhaust and check if its low also start the car and take the radiator cap off, is there exhaust coming out oh and if you have a DVOM (digital OHM Volt meter) you can check to see if the distributor coil is in specs ill go look for the primary and secondary specs and how do your points look on the cap?
Old Jul 16, 2005 | 09:33 PM
MkivTrd's Avatar
Default Re: my 91 CRX Si in SICK! HELP (mnhotrod2003)
looks like its the distributor, if i mess around with the wires that connect to the top of the distributor, it will run fine... i also replaced the main relay and it wasnt that.
how much will a dist run me?
Old Jul 16, 2005 | 10:01 PM
HBK's Avatar
HBK
depends on if its oem, used, or remanufacture plus core charge. a remanufacture i think goes for 150-200 i could be wrong, look it up online. i know OEM is like 400 or something outrageous
before u buy one, take the cap off and check your wiring, something might jsut be loose.
kodie
Feb 7, 2015 11:59 AM
tharedrexx
Jun 25, 2013 06:19 PM
roofracks91
Sep 16, 2012 02:49 PM
Mr_Moos
Feb 27, 2007 05:33 PM
Rikter
Jan 28, 2007 10:19 AM
