LS vtec monster in crx
Old Jul 14, 2005 | 04:53 PM
crxdude4675's Avatar
Default LS vtec monster in crx
I have a 1990 crx base model i recently got a b18a and am going to build a monster ls vtec . i plan to go all motor on this project can anyone help me decide on a trans such as gsr hydro or jdm b16 cable which would be best out of honda transmissions. i plan to make 225 hp and i want sumthin which will hold up good with a twin disc clutch let me know thanks......... =
Old Jul 14, 2005 | 05:16 PM
jedubz's Avatar
Default Re: LS vtec monster in crx (crxdude4675)
I'm going to tell you from experience because I drive an all motor LS/VTEC CRX.
First, my build is quite mild. PR3 (B16) H/C pisons bring the compression to 11.2:1, fairly high, but if you expect 225 whp, you're going to need a lot higher.
To give you an idea, with crappy intake and crappy exhaust I put down 161 whp untuned. Even with top name ****, J's or AEM Intake, Invidia Exhaust, and some 4-1 2.5 Collector Header, I wouldn't expect more then 185 whp once it's tuned.
So that's still 40 whp short of your goal.
To reach 225 whp, you're going to need not only high *** compression, but a fully reworked valvetrain, (CTR or better) with some very pricey cams. Not to mention a top brand intake manifold or individual throttle bodies, a very nice port and polish job on the head with a nice valve job. I would guess that with all those you're going to be sitting around 200 whp. Of course with that high revving of a valve train, expect revs of upwards of 9 grand, so you're going to definitely need some ARP Rod Bolts.
20 more whp to go.
Expect to now need some sort of fuel delivery system that can perfectly fit your needs. Not too bad, if you're really good with tuning you can use something cheap like a chipped PM6 with TurboEdit (what I use). But if you really want to get ever ounce of HP, you're probably going to want to go with something like AEM EMS or upgrade to OBD-1 and use Uberdata. More money.
In the end, I can't honestly say you're going to hit 225 with a modest NA set up. Pistons and Rods are probably going to be required. In fact I doubt you can do it for under $5,000 into the motor.
Best transmission you're going to get would be an ITR, or at least the final drive from it... but that means you're going to need to go Hydraulic which requires a conversion kit which is more $. I would just get the B16 with LSD, and have it reworked for ITR Final Drive.
Either way... You'll have a ******* awesome motor and a hole in your pocket making you say "Hey, why am I still driving a CRX?"
Old Jul 14, 2005 | 06:32 PM
jake1511's Avatar
or you could just spend 2 grand on a h22a swap and slap some headers, cams, intake on there and you could come close to 220
Old Jul 14, 2005 | 06:34 PM
atomikpunx2's Avatar
who said he wanted whp...
he probably thinks 225 is some magical number that will make him happy...
build up a reliable ls vtec...
or a high compression b18a and let him enjoy some modest tq he's been missing with the 1.5 of his.
Old Jul 14, 2005 | 07:06 PM
siR cr-x's Avatar
Default Re: (jake1511)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jake1511 &raquo;</TD></TR><TR><TD CLASS="quote">or you could just spend 2 grand on a h22a swap and slap some headers, cams, intake on there and you could come close to 220</TD></TR></TABLE>
what are you talking about h22a with that **** you listed MIGHT make 200 maybe and he said he wanted to build a lsvtec. if your looking for a tranny get they ys1 92-93 gsr cable tranny and put in the ITR final drive
Old Jul 14, 2005 | 07:20 PM
NXLude's Avatar
Default Re: (siR cr-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siR cr-x &raquo;</TD></TR><TR><TD CLASS="quote">
what are you talking about h22a with that **** you listed MIGHT make 200 maybe and he said he wanted to build a lsvtec. if your looking for a tranny get they ys1 92-93 gsr cable tranny and put in the ITR final drive</TD></TR></TABLE>It all depends on your choice of h22 parts.....still I havent seen too many 225 whp lsvtecs.....Id like to see one, it would be neat-o
Old Jul 14, 2005 | 07:27 PM
Suck my DX's Avatar
unless you got the hook up or know how to custom fab urself there is no way u can put an h22 in an ef for 2g's
Old Jul 14, 2005 | 09:02 PM
jedubz's Avatar
Default Re: (atomikpunx2)
Let's try to stay on topic people! He said LS-VTEC let's share our knowledge instead of bickering about H22 pricing and H22 bolt-on power.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by atomikpunx2 &raquo;</TD></TR><TR><TD CLASS="quote">who said he wanted whp...
or a high compression b18a and let him enjoy some modest tq he's been missing with the 1.5 of his.</TD></TR></TABLE>
I assumed he meant whp because he said he wanted it to make that much horsepower, and unless he's psychic he's only going to know whp from a dyno.
Either way it's attainable. However, I very strongly don't recomend going with a high-compression B18a.
First off, high compression motors are expensive to build, and you are starting with jack **** if you're using just a regular LS. Do you realize how much would have to be dumped into an LS to get it to be a good NA motor. Your starting with a **** valve train and no compression.
If you're going to spend the money on a B-series swap, and you're staying NA, you're a moron if you go non-Vtec. Torque is great, but horsepower wins races. You are shooting yourself in the foot if you leave that LS head on an NA engine.
Old Jul 14, 2005 | 09:11 PM
Suck my DX's Avatar
Default Re: (jedubz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">You are shooting yourself in the foot if you leave that LS head on an NA engine. </TD></TR></TABLE>
true that...if u r gonna stay non vtec go with the b20 head...better flow u will see noticable gains for sure...but i would still go with the vtec head
Old Jul 15, 2005 | 05:06 AM
jedubz's Avatar
Default Re: (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">true that...if u r gonna stay non vtec go with the b20 head...better flow u will see noticable gains for sure...but i would still go with the vtec head</TD></TR></TABLE>
Once again NO! Do not go non-vtec head if you're going NA. Do not listen to this guy. The B20 head is the same thing! The only good B-series head is a VTEC head!
Old Jul 15, 2005 | 06:21 AM
Suck my DX's Avatar
true that...if u r gonna stay non vtec go with the b20 head...better flow u will see noticable gains for sure...but i would still go with the vtec head</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jedubz &raquo;</TD></TR><TR><TD CLASS="quote">
Once again NO! Do not go non-vtec head if you're going NA. Do not listen to this guy. The B20 head is the same thing! The only good B-series head is a VTEC head!</TD></TR></TABLE>
dont talk **** fool...if u can read i clearly say that vtec head is better...b20 head has larger intake ports and will yield better results...i would never go non-vtec for n/a..unless u throw in those toda vtec killers
Old Jul 16, 2005 | 01:56 PM
jedubz's Avatar
"Dont talk **** fool?" What is your deal?
Do a search the b20 head is the same ******* head as on an LS. It's even stamped the same on every single part!
It may have some microscopic difference in intake runners but it is a TERRIBLE head! You are recomending someone who already that head (on his LS motor) to go out and WASTE his money on a B20 head. That is 100% BAD advice.
So don't give me this tough guy attitutude. I'm the one trying to help him out, giving him an experienced stand point (I have an LS/VTEC IN my car with his bottom end and I've been in his shoes.) and you're telling him to throw his money down the drain. Stop giving him bad advice and I wouldn't have to step in and correct you.
Modified by jedubz at 4:27 AM 7/17/2005
Old Jul 16, 2005 | 03:09 PM
All Motor Ek99's Avatar
just go ls vtec turbo 400whp all day
Old Jul 16, 2005 | 03:18 PM
myJDM89EF's Avatar
i would say stay cable and get a b16 cable tranny or a b18a cable tranny.
Old Jul 16, 2005 | 03:35 PM
trooper0641's Avatar
Default Re: LS vtec monster in crx (myJDM89EF)
b16 lsd cable tranny, oh and follow the 3 S's....STAY SOHC STUPID!
Old Jul 16, 2005 | 07:30 PM
jedubz's Avatar
Default Re: LS vtec monster in crx (trooper0641)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trooper0641 &raquo;</TD></TR><TR><TD CLASS="quote">b16 lsd cable tranny, oh and follow the 3 S's....STAY SOHC STUPID! </TD></TR></TABLE>
How the hell is he supposed to Stay SOHC using a b16a tranny?
For the last time let's just help him get what he wants instead of telling him he's wrong with what he wants or steering him in the wrong direction.
Remember the topic is:....
MONSTER
ALL MOTOR
LS-VTEC
IN A CRX
******* a. Honda-Tech
Old Jul 16, 2005 | 09:35 PM
djsire's Avatar
Default Re: LS vtec monster in crx (jedubz)
why dotn you just boost the ls. i would be happy with that!!!
Old Jul 16, 2005 | 09:52 PM
Skinflute22's Avatar
Default Re: LS vtec monster in crx (djsire)
someone's menstrol......
Old Jul 17, 2005 | 07:31 AM
PIMPALA-SS's Avatar
Default Re: (NXLude)
there is one here in Tulsa, it runs consistant mid 11s
he is only 220 whp
jamil0524
Oct 30, 2015 06:44 AM
1YellowSol
Mar 20, 2014 03:57 AM
CRXstress
Jul 6, 2005 03:28 PM
czech09
Oct 16, 2003 07:31 PM
NightHawkC5
Dec 12, 2002 09:21 AM
