Rear mount delima!
I just install a LS vtec. B18b block, B16 tranny. I cant figure out witch rear T mount have to install..I tried the stock D serie(i knew it wouldn't fit), and I just tried a LS mount and it doesn't fit. I don't know what the hell is going on. I just spent the last 3 hours changing that mount and it doesn't fit. The tranny is from an old B16 88-91??( I don't know the years exactly). Maybe that's the problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pete_SI »</TD></TR><TR><TD CLASS="quote">Sorry I should specifie more...I have a EG and I mean I use the LS braket...It's still the stock mount.</TD></TR></TABLE>
yes, correct. the ls bracket will work. not sure on the tranny issue. is it still a hydro clutch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">
yes, correct. the ls bracket will work. not sure on the tranny issue. is it still a hydro clutch?</TD></TR></TABLE>
Yeah it's hydro. I think I will have to get you guys pics.
The 2 top pictures are the same just different angles and the last one is the bolt that connects to the engine...The mount uses a 19mm bolt anfd a 19mm blolt doesn't fit in the hole in the block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">It really should fit no issues - maybe its not aligned correctly. Have you tested the bolt w/o a mount? Work to do so, I know</TD></TR></TABLE>
I cant push the mount to le right anymore because as you can see from the last picture the block is stoping me. It's hard to explain with word without seeing it. The last thing is to check if it's really a LS mount.I saw the guy from the junkyard take it out of the teg so. I will take it out tomorow and take pics and compare.
