Ls crank into gsr block = what kind of thrust washer??
Old Jul 14, 2005 | 03:02 PM
blu3g's Avatar
Default Ls crank into gsr block = what kind of thrust washer??
hey guys im throwing in a ls crank into my gsr block. When I pulled out the main caps two thrust washer fell out. My question would be should i use ls thrust washer or gs r thrust washer? Or are they the same and it wouldn't matter. Also I believe ls thrust washer is located differently from the gsr washers. I am confused please help me. Anyone???
Old Jul 14, 2005 | 03:04 PM
X-Mazda 3 Racer's Avatar
Default Re: Ls crank into gsr block = what kind of thrust washer?? (blu3g)
They are exactly the same and in the same location. You can drop the crank right in, just make sure the thrust washers are not damaged
Old Jul 14, 2005 | 03:11 PM
blu3g's Avatar
THANK YOU THANK YOU THANK YOU!!!
Old Jul 14, 2005 | 09:52 PM
earl's Avatar
Default Re: (blu3g)
All B series mains and thrusts are the same.
03EM2guy
19
Mar 28, 2011 06:00 AM
turbodegsi
Nov 10, 2005 09:22 PM
86si
Nov 6, 2004 06:43 AM
black-hatch
Mar 13, 2003 08:54 PM
